22893 Discussions
Can't find the name of the Intel ICD OpenGL driver
BDimm1
I have an HP Envy 750-424 desktop with an Intel HD 530 graphics driver. This morning Windows automatically updated the graphics driver, and Chrome stopped working with an OpenGL ES Error dialog box stating "Can't find the name of the Intel ICD OpenGL driver." I rolled back the driver from 21.20.16.4574 to 20.19.15.4454 and it fixed the issue. However, I suspect Windows will keep automatically updating the driver and causing this issue (it happened once before, with a different version number, and I was able to fix it with System Restore, so it seems to be a recurring problem). I have seen in other discussions that some drivers are provided by Intel and some are customized by manufacturers--is 21.20.16.4574 provided by Intel or by HP? Is this a bug that will be addressed ina future driver version?
Version 21.20.16.4574 is not a driver that was released by Intel. The latest version we offer would be 4552.
Does this problem happen after testing https://downloadcenter.intel.com/download/26464/Intel-Graphics-Beta-Driver-15-45- 4552?
Please let me know if you still have this issue with the latest generic Intel® graphics driver.
Allan.
Were you able to test driver version https://downloadcenter.intel.com/download/26464/Intel-Graphics-Beta-Driver-15-45- 4552?
Allan.
LCox1
I have the same problem. I have a new Medion MD60150 (8 februar 2017) Intel Core i3-7100U CPU @ 2.40 GHz 2.40GHz RAM 4 GB Grafic Intel HD620
I have problem with this program find on You tube https://www.youtube.com/watch?v=r693Xb9t4dI&t=416s Advanced Arduino Telemetry and Data Visualization - YouTube
With start problem Open GL ES Error Can"t find the name of Intel ICD Open GL driver.
I have tried the last update and the problem is the same.
Hope on a solution.
sorry for my English
Thank you for the information.
Intel just released new driver version 4590 compatible for your graphics controller.
https://downloadcenter.intel.com/download/26563/Graphics-Intel-Graphics-Driver-for-Windows-15-45-?product=88345 https://downloadcenter.intel.com/download/26563/Graphics-Intel-Graphics-Driver-for-Windows-15-45-?product=88345
If the problem remains, please fill out this form in order to forward it to the appropriate department /thread/77761 https://communities.intel.com/thread/77761
Allan.
LCox1
It's works now good. My friend has found the problem. My notebook is new.I think normal all programms from Microsoft on this notebook 64 bits. I use Internetexplorer 11 and that was a 32 bits in Windows 10.
After that have I installed Java . And Java had also installed in 32 bits .
Now is Java and Internetexplorer in 64 Bit version. Now I happy. It's works good.
Thanks Allan for your help.
I am glad this is working for you. Thank you for taking the time and provide this feedback.
Allan.
BDimm1
I have not tried 4552 yet because the rolled back version is working and I don't know how to back it up in case 4552 doesn't work. However, I think it may be relevant, based on the other responses, that I have a 64 bit system but am running a 32 bit version of Chrome (which I use because the 64 bit version is incompatible with other software I use. Chrome si the program that originally gave me the error. So it may be that running 32 bit programs on a 64 bit system causes the problem with this driver.
RBalt1
Latest driver and the problem still exists. My problem is with origin setup. It can not start, giving Can´t find the name of Intel ICD openGL driver.
SNaik3
Hi....even I am facing the same issue. I tried upgrading my display drivers and my current config is:
Intel HD Graphics 620: 21.20.16.4541
NVIDIA GeForce 940MX: 21.21.13.6942
Windows 10: 64 bit operating system
Let me know how I can solve this issue?
Sandesh
If you are still experiencing same issue after testing driver https://downloadcenter.intel.com/download/26563/Graphics-Intel-Graphics-Driver-for-Windows-15-45- version 4590 and your computer manufacturer's drivers. Please fill out the following form as complete as possible.
To attach a file, you must click "Use Advanced Editor" in the top right corner of the response box, then the "attach" option will appear in the bottom right corner of the response box.
Allan.
RBalt1
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Error when trying to launch Origin setup: Can't find the name of the Intel ICD OpenGL driver
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
MSI GS43VR 7RE
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
Hybrid. HD 630 and GTX 1060
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)<td style="padding: 0 5.4pt; border-top: none; border-right: 1pt solid windowtext; border-bottom: 1pt solid windowtext; border-left: none; font-style: inh...
SNaik3
Category
Questions
Category
Questions
Description
I tried running a "JNLP" file 'discover' (please check the attachment for file) and received OpenGL error (screenshot attached) hence checked the Intel Forums for resolution and came across one response from Intel asking to download version 4590 drivers. After downloading when I tried to run the application I received another error for system incompatibility (screenshot attached); thus filling this form to get resolution for OpenGL error I am receiving
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):</span>
<span style="border: none windowtext 1.0pt; padding: 0cm; mso-fareast-font-family: 'Times New Roman'; mso-border-alt: none ...
Thanks for the information, I am still testing this issue. This thread will be updated as news become available.
Allan.
RBalt1
Here is another useful report for you. Created with Process Monitor.
RBalt1
Solved by updating to build 15042.
Great information coolrecep, I am glad you have fixed this issue by updating to the latest Windows® 10 patch
I have tried to replicate this matter with Windows® 10 fully updated and the latest graphics drivers version https://downloadcenter.intel.com/download/26604/Graphics-Intel-Graphics-Driver-Beta-15-45- 4614 and I did not get same problem.
To all, please confirm if you were able to update Windows. Thank you for your time.
Allan.
SNaik3
Hi Allan,
As you can see the form filled by me, my machine has latest hardware installed. Do I still needs to take any further measures to solve OpenGL issue? if so, please provide details like link to download any latest driver etc. I am not a tech savy guy so might need some assistance in getting this resolved.
Sandesh
SNaik3
Hi Allan,
Thanks for your response.
I didn't received any update information for my system when I checked for the updates through settings. And with latest driver update, I continue to receive an error that "Driver being installed is not validated for this computer" and suggests me to obtain appropriate driver from manufacturer.
Let me know if you need any further info around my system and request to give me the solution on this at your earliest.
I've attached the relevant screenshots for your reference.
Sandesh
