23075 Discussions
intel hd graphics 3000 problema con coneccion hdmi
jgome22
Buenos dias tengo un problema al conectar mi hp elitebook 8460p atraves de la entrada dysplayport adapatada hdmi.
el driver del adaptaor de pantalla es un intel hd graphics 3000 lo he reinstalado al menos 6 veces por que lei que esa era la solucion.
el so de mi equipo es windows 10 de 64 bits, aunque tambien intente con windows 7 ultimate y me sucede igual.
la coneccion: adaptador display port a hdmi+cable hdmi to hdmi (ambos genericos)
no se que mas hacer. agradeceria su ayuda o comentarios sobre el tema, si necesitan informacion adicional respondere tan rapido como pueda
gracias de antemano
AlHill
Intel HD 3000 graphics is not supported on windows 10.
You may want to try the drivers listed here: https://www.catalog.update.microsoft.com/Search.aspx?q=intel+hd+3000+graphics Microsoft Update Catalog
Doc
jgome22
thanks for answering.
I have dual boot with windows 7 and it does not work
The only thing I can think of is a compatibility problem with the cable adapter, although it does not make sense
sorry for my English is not very good
AlHill
It is possible that the cable adapter is a problem. The use of adapters is not supported.
Doc
jgome22
ok fd.
Regarding the adapter, do I have to buy one recommended by hp? or just will conect it dp to dp cable ?
AlHill
There are adapters which may work, depending on specifications and cost.
Given the choice, I prefer HDMI to HDMI or DP to DP, using quality cables, and since I do not like adapters.
Doc
jgome22
thanks for the help, i will try with vga to hdmi
regards
jgome22
ok i download the driver from the page, I have to unzip the file?
AlHill
Yes. This document may help you:
https://www.intel.com/content/www/us/en/support/articles/000005474/graphics-drivers.html How to Manually Install an Intel® Graphics Driver in Windows 7*
Doc
jgome22
