23271 Discussions
Can't get 1440x900 res. with Intel 82945G Express Chipset
I have a 19 inch monitor, resolution 1440x900. I can't get that resolution. Intel has released a graphics driver to specifically address this issue, I dowloaded and ran the file, but it installed the old driver. What should I do?
My fist suggestion is to install the monitor driver. It is usually provided with your monitor and you can also download it from the monitor manufacturers web site.
Make sure that you are not using any adapters. If your computer has a DVI port your monitor should be DVI also.
Only to confirm the driver that was developed for this issue is the following:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18232&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18232&lang=eng
PV.
