22671 Discussions
Can't get dual / extended screen to work, gives boot-time error
BSimp3
Débutant
1 803 Visites
Hello all,
I get this on startup:
This computer has an add in graphics card, but the monitor cable is plugged into the integrated video connector. To attach the monitor cable to the add-in graphics card:
1. Shut down the computer
2. Plug the monitor cable into the add-in graphics card connector. This may require a video adapter or video adapter cable.
3. Turn on the computer
I am running a Dell, GX620 Optiplex with Intel Pentium D 2.8gHz processor, 2 gb ram, running windows 7 Ultimate. The Graphics card is a brand new Radeon Saphire HD5450
Theoretically, I should be able to enter BIOS and select the OnBoard VGA as always enable, and the PCI-E as enabled.
However, I seem to only be able to do One or the Other, not Both.
I want extended desktop across 2 VGA monitors
Can anyone point me in the right direction?
0 Compliments
1 Répondre
Silvia_L_Intel1
Employé
904 Visites
Hello CrazySparky, thanks for joining the Intel Community.
It is important to tell you that some systems do not allow using the onboard video and a video card at the same time. Most of the time, once you installed a Video card on the motherboard; the onboard video gets disabled automatically.
I would recommend you to contact DELL in order to check if your system is capable of using the onboard video and the video card simultaneously.
0 Compliments
Répondre
