Hello ,
I am trying to install UHD 750 on my i5-11600k , but i am facing the following problem .
" wasn't able to find any controller that, can be installed on actual device"
Is there any solution ? I have tried the latest ones . https://www.intel.com/content/www/us/en/products/sku/212275/intel-core-i511600k-processor-12m-cache-up-to-4-90-ghz/downloads.html
Best regards .
Skizpt
skizpt, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of the motherboard?
Is this a new computer?
Did you build it?
Were you able to properly install the driver before?
When did the issue start?
Did you make any recent hardware/software changes besides installing the new driver that might cause this problem?
Which Windows* version are you using?
Albert R.
Hello ,
Thanks for the help , but i found it yesterday , that i had to activate multi monitor on my bios of ASUS motherboard , and it worked .
Best regards ,
Rolando
Hello skizpt, You are very welcome, thank you very much for letting us know those results.
"i had to activate multi monitor on my bios of ASUS motherboard , and it worked":
Perfect, excellent, it is great to know that after activating multi-monitor in the BIOS of the board it now worked.
Any other inquiries, do not hesitate to contact us again.
Albert R.
