22944 Discussions
Can't overclock my HD4000
Intel Extreme Tuning Utility can't see Graphics tuning menu (sorry for my bad eng.)
NICHOLAS_F_Intel
Hi waynebliss,
What version of the Intel® Extreme Tuning Utility™ are you using?
-Nic
Hi nic
I'm not sure about version of XTU (maybe 3.2.0.24)but, I'm sure I used latest version XTU.
Thank you for your help Nic.I appreciate
NICHOLAS_F_Intel
I've got 3.2.0.24 installed on an HD 4000 configuration right now, and I'm seeing both options for manual tuning, as well as specific tab for graphics overclocking.
Can you try downloading the latest from here; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3483&DwnldID=21743&keyword=Intel+Extreme+Tuning+Utility&DownloadType=Software+Applications&lang=eng Download Center
Let me know if this works.
-Nic
Sorry to say that it doesn't work Nic
i using acer s3-391 and result is can't overclocking
i5 3317U
NICHOLAS_F_Intel
@waynebliss: Sorry for the delayed response. This is most likely a setting that your OEM has disabled, which is why you aren't provided the option with XTU.
@Son Nguyen Duc: Are you using the Intel® Extreme Tuning Utility™ and are also unable to see an option for overclocking the graphics core of your processor?
-Nic
Hi , i am witnessing the same problem, but it gives me the option to enable, so i enable it, and then it gives me the option to tune it, so i do, then it disables straight after i click apply. why is this ?
NICHOLAS_F_Intel
Hi Jake. First off, are you using the latest version of the Intel® Extreme Tuning Utility for Windows 8? (Here's the link; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21743&ProdId=3483&lang=eng Download Center)
Also, are you running the display off of Intel® graphics, or a discrete graphics card in your system? If your OEM has disabled the use of overclocking, it may manifest itself differently than other blocked users due to it being from a different OEM.
There is an ( i ) button next to the enable/disable button, as well as an ( x ). Does the 'i' give any useful info?
You might also check your BIOS and see if you can toggle/change the max graphics frequency to something higher than 350 MHz.
-Nic
JPier6
I am having the same problem as jake. The tuned options just won't apply.
The says: Default: disable, Active: disable, Proposed: disable
NFabe
I am having problems with the Intel Extreme Tuning Utility as well; I can't manually tune, however I have Intel Turbo Boost and everything. I can't control the Manual Tune tool, anyone have any suggestions on how to fix this? Again, I tried everything. Extreme Tuning Utility is up to date as well.
NICHOLAS_F_Intel
Hi Vgrc4life,
Are you trying to overclock the processor or the graphics core on the processor? Are you using a desktop or a laptop? If you are experiencing the same symptoms that Jake was - please refer to my response to him from a year ago.
-Nic
MHada1
Hi to Everyone
All problems about the Manual Tuning Part with Downloading new Version of Software "Intel(R) Extreme Tuning Utility" can be Solved.
any body can tell about range of overclocking on
CPU Core i7 3520m
and
Intel Graphic 4000 HD
