23851 Discussions
Cannot enable retro scaling in Intel Graphics Software control panel
dantmnf2
The "Retro scaling" option in Intel Graphics Software does not work, choosing it results in some flicker and revert to GPU scaling.
Arc Control from older driver package can enable retro scaling without issues.
RandyT_Intel
Hi @dantmnf2,
I just wanted to clarify if the flickering issue is happening on the main screen or the external monitor after updating to version 6653. Could you also let me know the older driver version that did not have an issue with retro scaling? Apart from the driver update, have you checked for any Windows updates or patches for the system?
Randy T.
dantmnf2
To clarify, I am changing the scaling mode of internal display from "GPU Scaling" to "Retro Scaling" in Intel Graphics Software. After I click "Retro Scaling“ option in the popup list, the screen flickered for about one second, then the scaling mode is still "GPU Scaling".
Also with the 6653 driver, using Arc Control from 6130 driver package can enable retro scaling without issues. Intel Graphics Software cannot detect retro scaling status (still reports "GPU Scaling") and any change to scaling mode/method will disable retro scaling.
No older driver versions with Intel Graphics Software tested.
RandyT_Intel
Hi @dantmnf2,
To help isolate the flickering issue with retro scaling, could you please test using an external monitor connected to your system? Let us know if the flickering occurs on the extended display or only on the internal screen.
Additionally, please check for any pending BIOS updates on your system manufacturer's website and ensure all Windows updates are installed. Remember to reboot your system to apply any changes.
Since the issue is occurring with version 6653, it may be driver related. Could you let us know how you performed your last graphics driver update? Did you obtain version 6653 from the Intel Download Center or from your system manufacturer? Did you performed clean installation before updating your graphics driver?
Please note that Intel provides generic versions of software and drivers. Your computer manufacturer may have altered the features, incorporated customizations, or made other changes. If you have an OEM device, contact Computer Manufacturer Support Websites for best driver compatibility with your system.
Thank you for your cooperation, and we look forward to your observations.
Randy T.
RandyT_Intel
Hi @dantmnf2,
Randy T.
dantmnf2
I didn't get a chance to test on external monitor yet. The driver is obtained from Intel Download Center website, without performing a clean installation.
RandyT_Intel
Hi @dantmnf2,
Thank you for your update. I understand you haven't had the chance to test on an external monitor yet. When you do, please try to follow the recommendations provided in my previous post to ensure optimal performance.
Additionally, I wanted to inform you that we have a new driver version available, 32.0.101.6732, which you can download from the Intel Download Center. I recommend performing a clean installation of previous driver to ensure all settings are reset and to potentially resolve any existing issues.
Please note, we supply generic versions of graphics drivers for general purposes. Computer manufacturers might have changed the features, incorporated customizations, or made other changes to the graphics driver software or software packaging. To avoid potential installation incompatibilities, we recommend that you check first with your computer manufacturer and use the driver software provided by them
Once you've applied these steps, please test the scaling on your system and let us know how it goes. Your feedback is valuable, and we're looking forward to your response.
Randy T.
dantmnf2
Performed a clean installation with 6732 driver, the retro scaling option in Intel Graphics Software does not have any effect now - neither flickering nor scaling behavior change.
Reopening Intel Graphics Software after switching to retro scaling will get two empty option:
RandyT_Intel
Hi @dantmnf2,
I would like to offer remote assistance to help check your system and address the issues you're experiencing. I will be sending you an email shortly to request your callback number so we can discuss this over the phone.
My plan is to personally explore and examine the Intel graphics software on your system using the Quick Assist application that can be downloaded from Microsoft store. This will allow me to identify any settings that may need to be enabled or determine if there is a software glitch that should be reported.
I appreciate your cooperation and look forward to working with you to resolve this issue. Please anticipate an email from me later today or by tomorrow.
Thank you.
Randy T.
RandyT_Intel
Hi @dantmnf2,
Just checking in on my previous message regarding this concern. Have you had a chance to check your email? If you need more information or have any questions, feel free to reach out. I'm here to help!
Thank you.
Randy T.
NormanS_Intel
Hello dantmnf2,
Thank you for bringing this issue to our attention. We are currently looking into it and will keep you informed as soon as we have more information.
Norman S.
RandyT_Intel
Hi @dantmnf2,
Following our investigation, we are pleased to inform you that the issue you experienced has been resolved in the latest graphics driver version.
Please install the graphics driver version 32.0.101.6790 WHQL Certified (Latest), which includes IGS 25.14.1302.1. This update addresses the issue and should enhance your system's performance.
Important Installation Steps:
  1. Before installing the new graphics driver, ensure a clean installation using DDU (Display Driver Uninstaller). This step is crucial to remove any remnants of previous drivers and prevent potential conflicts.
  2. Proceed with installing the graphics driver version 32.0.101.6790 WHQL Certified.
If you have any questions or need further assistance, please feel free to reach out. We are here to help.
Thank you.
Randy T.
dantmnf2
Unfortunately the 6790 driver doesn't solve the issue for me. I have tried both clean install option in installer and DDU, getting same behavior as previous drivers on my side.
RandyT_Intel
Hi @dantmnf2,
Thank you for providing an update. Since that 6790 driver hasn't resolved the problem for you. I will pass this outcome internally for further investigation to ensure we address the issue effectively. I appreciate your patience and understanding as we work towards a solution.
Randy T.
RandyT_Intel
Hi @dantmnf2,
I wanted to let you know that I have sent an update directly to your email. Please take a moment to check your inbox at your earliest convenience.
Thank you for your attention to this matter.
Randy T.
DhannielM_Intel
Hi dantmnf2,
Thank you for your response and for keeping me informed. I will continue to investigate this issue and will update you as soon as I have more information.
Dhanniel M.
