23259 Discussions
Intel ARC A380 screen flickering, how do I fix this problem?
SalmanMahmud
When I launched Edge browser this flicker is happen like crazy sometimes this problem happen in other app also but in Microsoft edge its happen more. When this problem occurs I close my Edge browser and reopen it  then this problem is gone but after shut down and open my pc this problem is coming back again. This problem occurs some times.
Please help me regarding this issue.
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is this generation's XP]
SalmanMahmud
Already added the txt file
