22850 Discussions
Cannot get /dev/dri to appear in WSL 2 for Intel Iris Xe (12th Gen i5)
Himanth_Reddy
I've been trying to get Intel QSV hardware acceleration working for a Jellyfin container in Docker Desktop (on WSL 2) to stop high CPU usage and video lag.
The root problem is that the /dev/dri device is not being created inside any of my WSL 2 distributions, so Docker can't pass the GPU to the container.
When I run wsl ls -l /dev/dri in any distro (including a brand new Ubuntu Server install and Debian), I get: ls: /dev/dri: No such file or directory
This causes my Jellyfin container to fail, and without hardware acceleration, my VmmemWSL process hits >50% CPU usage and videos lag.
Then I tried to dive deeper into the problem using chatgpt, It asked me to see the Driver Version and Driver Model using Get-CimInstance Win32_VideoController | Select-Object Name, DriverVersion, DriverModel Then it returned with
Name                                      DriverVersion     DriverModel
Intel(R) Iris(R) Xe Graphics 32.0.101.6790
It did not give me any Driver Model
My Configuration
  • OS: Windows 11 25H2
  • CPU: 12th Gen Intel i5 'U' series
  • GPU: Intel Iris Xe Graphics
  • WSL Version: WSL 2 (running the Docker Desktop backend and a fresh Ubuntu Server)
  • Driver Version: Intel(R) Iris(R) Xe Graphics 32.0.101.6790
This seems to be a driver-loading issue between Windows and WSL 2. Has anyone seen this with a 12th-gen Iris Xe chip and found a fix?
Thanks!
JedG_Intel
Hello Himanth_Reddy,
I've reviewed your inquiry and would like to point out that WSL2 implements GPU passthrough differently from standard Linux, you should be looking for /dev/dxg rather than /dev/dri. This is likely the core issue preventing your Intel QSV hardware acceleration from working properly.
With this in mind, I would like to clarify the following:
1. Just double checking, Have you enabled GPU passthrough in your .wslconfig file with [wsl2] and nestedVirtualization=true?
2. Can you run wsl --update and wsl --version to ensure you have the most recent WSL2 kernel that supports GPU passthrough?
3. Can you run ls -l /dev/dxg instead of /dev/dri? In WSL2, GPUs are typically listed under /dev/dxg rather than the standard Linux /dev/dri path
4. Can you run lspci | grep VGA to see if WSL2 recognizes your Intel Iris Xe graphics
5. Are you using --device /dev/dxg instead of --device /dev/dri in your Docker run command or docker-compose file?
6. Since /dev/dxg is the correct path for WSL2, have you updated your Jellyfin container configuration to use this device path instead?
Best regards
Jed G.
JedG_Intel
Jed G.
