22684 Discussions
Cannot install Intel HD graphics driver on X553M Windows 7 - 32
АТолм
Help please!
I have installed Windows 7 Ultimate 32 on my new Asus X553M and I have successfully installed all drivers except Intel HD graphics.
I am getting "The computer does not meet the minimum requirement"
I am downloading old and new drivers from Intel - does not work
I am downloading zipped and exe versions of driver - does not work
I am downloading http://www.intel.com/support/graphics/detect.htm Intel® Driver Update Utility. It detects the video but can not install the driver.
I am trying to update the driver through "Update driver" system option - does not work.
Processor - M Quad-core 3530
What am I doing wrong?
АТолм
System Information
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: X553MA
BIOS: BIOS Date: 06/27/14 12:16:09 Ver: 05.06.05
Processor: Intel(R) Pentium(R) CPU N3530 @ 2.16GHz (4 CPUs), ~2.2GHz
Memory: 4096MB RAM
Available OS Memory: 2958MB RAM
Page File: 3287MB used, 2627MB available
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
Display Devices
Card name: Standard VGA Graphics Adapter
Manufacturer: (Standard display types)
Chip type: Intel(R) VLV Mobile/Desktop Graphics Chipset Accelerated VGA BIOS
DAC type: 8 bit
Device Key: Enum\PCI\VEN_8086&DEV_0F31&SUBSYS_161D1043&REV_0E
Display Memory: n/a
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 1366 x 768 (32 bit) (1Hz)
Monitor Name: Generic PnP Monitor
Monitor Model:
Monitor Id:
Native Mode:
Output Type:
Driver Name: vga
Driver File Version: 6.01.7600.16385 (Russian)
Driver Version: 6.1.7600.16385
DDI Version: unknown
Driver Model: unknown
Driver Attributes: Final Retail
Driver Date/Size: 7/14/2009 02:25:51, 10752 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4C71-11CF-F233-AD2BA0C2CB35}
Vendor ID: 0x8086
Device ID: 0x0F31
SubSys ID: 0x161D1043
Revision ID: 0x000E
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Kevin_M_Intel
Hello AlexTol,
Thank you for sharing all this information.
The reason why you are getting this message during the installation of the driver is that our drivers are generic software for OEM systems. Computer Manufacture design and create their own systems with special features that will be lost when installing our driver.
Checking on the computer specifications, it was intended to run Windows 8 and Windows 8.1 as per the OEM.
There is a workaround for this. Check the following link:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
Please try this driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24346&lang=eng https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24346&lang=eng
If you are still having problems, my best recommendation is to contact your Computer Manufacture and get their special driver.
Kevin M
АТолм
Thank you Kevin!
I tried it. But still does not work.
I do appreciate a lot your help. Will try to fight with windows to install the drivers.
Probably I have to edit registry...
Unfortunately the manufacturer provides only Windows 8 drivers and I do not want to use this OS.
Kevin_M_Intel
АТолм
For those who has the same problem (if I am not alone ) - do not try 32 bit version of Windows 7 on Asus X553M - no way to install video drivers correctly.
So finally I reinstalled the version of Windows to 64 bit and could install Intel drivers 64 bit version.
And Kevin is the best expert to help with such issues!
Kevin_M_Intel
Thank you for this comment. I am glad to hear it is working for you now.
Kevin M
STole1
Im having a problem like that too .. i reformated my acer laptop from windows 8.1 to windows 7 ultimate . i updated all my drivers but my graphics card didnt update. i tried to update via Intel Driver Utility but it wont detect my graphics . im using windows 7 ultimate 32bits . i tried the link here but it says "this is not compatiblee in your operating system" even thou im using windows 7 32bits . anyone pls help thanks
Doko .
Kevin_M_Intel
Hello Dokobobet,
This thread has been responded and solved to the OP. Please create a new thread and provide the system report.
System Information: Click Start> Type System Information> Click File> Export> Save File> Attach using Advanced Editor Options.
Here you can create a new thread:
/community/tech/graphics https://communities.intel.com/community/tech/graphics
Kevin M
