21578 Discussions
Cant add custom resolution?
zdegore
I have a PLC system using Windows 10 IoT enterprise 2021, and intel HD graphics 500. I need to set the resolution to 800x480, however this is not an option, I've tried a variety of things CRU, editing reg values,  Set-DisplayResolution powershell module, but nothing works.
I have an older but very similar system which is instead using intel hd graphics and I was able to delete that driver and revert to the basic display adapter and set a custom resolution through reg values. However when I delete the driver for HD 500 system, it reverts to basic display adapter but it greys out resolution setting all together and I cannot set the resolution.
It also seems to be using a different driver file "...DriverStore\basicdisplay.inf_amd64_....\BasicDisplay.sys" as opposed to the older systems "...System32\drivers\BasicDisplay.sys"
Im not sure if there is a different way to set the resolution or if there is a way to switch the drivers on the current system?
Labels (2)
