22683 Discusiones
Cant update/use UHD610 on G5400
SSiem
Principiante
4.328 Vistas
im using the G5400 Processor on an ASUS ROG H370 I Gaming Mainboard win10 pro 64. My screen is lagging like a Graphiccard without a Driver. I've installed all Drivers from asus and used the Intel Driver and support Assistent. The assistend downloaded the Version 6025. But i cant install it, the Setup says that my pc is not the Right for that update. I've allready contacted the support of Intel, but there was no one who can help me. On the Intel Website is no where anything About the UHD610.
I hope anyone understand my words and can help me.
Best regards
0 kudos
9 Respuestas
Empleados
2.976 Vistas
Hello, Torni94.
I sent you a private message, please verify your inbox.
Antony S.
ACoop1
Principiante
2.976 Vistas
I am having the exact same issue. The Pentium G5400 uses the UHD610 graphic processor but there appears to be no compatible driver for this. Drivers that support UHD600, 605 or 620 are all saying they are incorrect for the UHD610.Torni94 did you get a solution?
ACoop1
Principiante
2.976 Vistas
[SOLVED]
I resolved the issue by installing a slightly older version of the video driver package.
I found a copy of 24.20.100.6025 dated 26 April 2018 and this worked.
Version 24.20.100.6194 dated 11 July 2018 DOES NOT install on a G5400 system.
https://downloadcenter.intel.com/search?keyword=uhd+graphics Search downloads
psegu
Principiante
2.976 Vistas
Hi, i've got the same problème. I try différent driver : win64_24-20-100-6025 ; win64-24-20-100-6286 ; win64-154602-4729 ; win64-1546054771. None works.
Someone has another idear ?
snaru1
Principiante
2.976 Vistas
psegu
Principiante
2.976 Vistas
Good evening, problem solved by reinstalling windows10.
mcej0
Principiante
2.976 Vistas
hello what windows version you install
mcej0
Principiante
2.976 Vistas
because i cant install graphics in g5400
ACoop1
Principiante
2.976 Vistas
Responder
