22644 Discussões
Coil Whine in Asus Laptop from intel HD graphics 530
RGóme1
Novato
11.464 Visualizações
Hello to everyone!
This is my first topic on this forum, and I expect you can help me with this annoying problem that has been disturbing me for some days.
Recently, I bought an ASUS R510V laptop with freeDOS as OS, 8 GB RAM, intel i7 6700HQ, GTX 950M as dedicated GPU, and intel HD graphics 530 as integrated GPU.
About 2 weeks after installing Windows 10 and Ubuntu 14 I realized that, sometimes, a high-pitched noise came from inside the laptop (http://vocaroo.com/i/s1Y3CV2BcPQO hear the noise). Surfing the internet I came to the conclusion that is coil whine, and I think its origin is the intel integrated graphics. First of all, this noise is produced only while using windows (not in ubuntu, where I can only use GTX 950M GPU), specially in the screen that appears when an application needs special permissions, or in applications like Google Chrome. I have updated my Intel drivers too.
But the most strange thing I have discovered recently is: this noise does not show up while the Intel Driver Update Utility or the Intel Graphics HD control panel are running in foreground.
Do you have any idea why is this happening? Any suggestion to solve this problem apart from having Intel Driver Update Utility or the Intel Graphics HD control panel running?
Thank you so much anyway and sorry for my English!
18 Respostas
Funcionário
7.756 Visualizações
I have listened to the audio and does seem really strange.
Let's start by updating to the latest graphics drivers available https://downloadcenter.intel.com/download/26464/Intel-Graphics-Beta-Driver-15-45- here they would be version 4552
It will be good if you could test customized drivers from http://www.commercialsupport.asus.com/downloads Asus and let us know if both drivers are the same.
Allan.
RGóme1
Novato
7.756 Visualizações
I have downloaded and installed both and nothing changes. This is the driver in the Asus page. Thank you very much for your answer
Funcionário
7.756 Visualizações
Thanks for the information. After loading both drivers, you see this is not a software issue. This seems to be hardware and the best way to check it would be contacting your computer manufacturer.
This is the contact information from Asus
https://www.asus.com/us/support/callus https://www.asus.com/us/support/callus
Allan.
RGóme1
Novato
7.756 Visualizações
But, if it's not a software issue, why is it solved when using Ubuntu or running Intel utilities on Windows 10?
Funcionário
7.756 Visualizações
Linux* and Microsoft* operating systems do not carry the same graphics engine. It might be that when using different operating systems the graphics frequency changes and that is why you are getting this high pitch noise, again, hardware issue.
Allan.
RGóme1
Novato
7.756 Visualizações
and how about the Intel applications? Yesterday I installed a Virtual Machine with Windows 7 and no coil whine
Funcionário
7.756 Visualizações
Since the graphics is integrated on the processor. You could try running a test and this will let us
know if the graphics portion of the processor has something wrong.
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Intel® Processor Diagnostic Tool
Allan.
RGóme1
Novato
7.756 Visualizações
I downloaded and ran it and everything was ok. Thank you so much!
Funcionário
7.756 Visualizações
Good to hear this is working for you. Thank you for the update.
Allan.
RGóme1
Novato
7.756 Visualizações
Hi again! I have made some importants discoverments. First of all, with Asus Live Update, there is no whine. But the most important changes are due to Power Plans in Windows:
With economizer there is no whine, and with high performance, a lot (with balanced, I can sometimes hear noise). But by changing some of the values in advanced settings the whine is gone. Specifically, in the Process Power Management: increasing (above 70%) the Minimum Processor State will cause coil Whine in Economizer mode to appear, and decreasing in Balanced mode to reduce it. Changing this and the other values in Process Power Managament has no effects on the High Performance plan (no noise reduction). Any idea of what is happening?
Funcionário
7.756 Visualizações
Thank you for the information, this is really an odd situation, I just keep thinking this is not a driver issue.
I think is a good time to contact Asus for hardware support.
https://cms-am.asus.com/ecp/Rma.html Asus support
Allan.
RGóme1
Novato
7.756 Visualizações
I have already sent an email to Asus Support. Waiting for the response in 48 hours. Thank you again!
BKono
Principiante
7.756 Visualizações
I have similar issue on my Dell Inspiron with the same Intel GPU.
You are lucky as you do not have Optimus technology used, therefore the sound is not very loud.
You could try using only Nvidia GPU (by disabling Intel GPU in BIOS) or try to disable C-States (in BIOS too).
RGóme1
Novato
7.756 Visualizações
I read about disabling C-States in Bios, but I have no option to configure CPU settings in my BIOS menu. Also, I have no possibility to disable intel GPU. Do you know why?
BKono
Principiante
7.756 Visualizações
ASUS does not allow to change it in BIOS, I guess.
You could try looking for modified BIOS on the Internet or modify yourself, but I am not sure if it is safe.
As do you not have Optimus technology (as far as I know) - you can try to disable Intel GPU in Windows Manager - it should work too.
RGóme1
Novato
7.756 Visualizações
I have disabled Intel GPU in Windows Hardware/Device Manager and no changes. My brother has the same laptop, and yesterday I discovered that it also had this annoying noise. So I imagine it's a problem with this model.
Thank you!
BKono
Principiante
7.756 Visualizações
Strange that it did not help.
If chrome and other applications are running on Intel GPU - could you try running them on Nvidia GPU?
Also, did ASUS reply to you?
RGóme1
Novato
7.756 Visualizações
Nothing changes when running them on Nvidia GPU. Asus has replied me today, but they haven't told me anything useful. I am seriously thinking that the problem's origin is the CPU.
Responder
