23823 Discussions
Compatibility with Monitor
Iratxe
I am thinking about buying a new monitor that has a resolution of 2560 x 1080 pixels. My laptop is a Dell Inspiron with graphics Mesa Intel® HD Graphics 620. Will I have problems with the monitor when displaying? (the monitor is a LG29WK600-W)
Thanks in advance
BHarr8
Valued Contributor I
Iratxe
I know that it is within the max resolution, but is the aspect ratio 21:9 supported correctly?
BHarr8
I am not sure from personal use but google results are not encouraging.
I am seeing a huge number of support requests pairing 620 Intel graphics with 2560X1800.
Unless you can get confirmation from Intel that they have released a driver that enables this resolution on the 620 graphics I would assume that this does not work.
Victor_G_Intel
Hello Iratxe,
In order for you to have more information on how your graphics work in regards to display resolutions please take a look at the following article and let us know if you have any doubt with the information on it.
https://www.intel.com/content/www/us/en/support/articles/000023781/graphics.html
I look forward to hearing from you.
Victor G.
Intel Technical Support Technician
Iratxe
Okay, thanks. So in my specific case, I can see that the maximum supported resolution is 4096x2304
This is a 16:9 aspect ratio, but I understand that 21:9 aspect ratio is also supported if the resolution is under this maximum suported resulution, am I okay?
Victor_G_Intel
Hello Iratxe,
As the article mentions, most devices will support any resolution and refresh rate up to the maximum value listed on the specifications page; however, to find the resolutions supported by your computer and display, you will need to check with those specific manufacturers, mostly because limitations on customized devices such as a laptop or a monitor can only be determined and tested by in this case Dell(Laptop) and LG(Monitor).
Victor G.
Victor_G_Intel
Hello Iratxe,
Please let me know if you need further assistance.
Victor G.
Iratxe
Sorry for the delay. Yeah, it is okay now. Thanks.
Victor_G_Intel
Hello Iratxe,
We will proceed to close this thread; however, if you need any additional information; you are more than welcome to submit a new question just remember that this thread will no longer be monitored.
Victor G.
