23787 Discussions
Computer freezes, blinking white black rectangle on screen
zmeu18041
Dear Support,
My computer freezes while I am working. The screen starts blinking with  white black rectangles. The only solution is to restart the computer. The Windows 11 Event section shows the following errors:
- <System>
  <Provider Name="Intel.GraphicsSoftware.App" />
  <EventID Qualifiers="0">188</EventID>
  <Version>0</Version>
  <Level>2</Level>
  <Task>3925</Task>
  <Opcode>0</Opcode>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2025-11-15T19:56:51.5610801Z" />
  <EventRecordID>2363</EventRecordID>
  <Correlation />
  <Execution ProcessID="2124" ThreadID="0" />
  <Channel>Intel Graphics Software</Channel>
  <Computer>sorin-dkpc</Computer>
  <Security />
  </System>
- <EventData>
  <Data>{"category":"Igcl","level":"Error","message":"3rd Party - IGCL ctlEnumLeds - Exception","parameters":{"result":1073741834}}</Data>
  </EventData>
  </Event>
- <System>
  <EventID Qualifiers="0">187</EventID>
  <Level>2</Level>
  <Task>3925</Task>
  <Opcode>0</Opcode>
  <TimeCreated SystemTime="2025-11-15T19:56:51.5607713Z" />
  <EventRecordID>2362</EventRecordID>
  <Correlation />
  <Security />
  </System>
- <EventData>
  <Data>{"category":"Igcl","level":"Error","message":"ctlEnumLeds, result=1073741834"}</Data>
  </EventData>
  </Event>
I attached the Intel Scan logs
Thank you for feedback.
zmeu18041
I suspect the Gigabyte Control Center. I deactivated the RGB fusion and removed it from automatically starting. I have no crash since then.
VonM_Intel
Hi zmeu18041,
Thank you for posting in our Community and attaching the Intel Scan logs. I understand that your computer is freezing while in use, with the screen displaying blinking white and black rectangles, and that the only current solution is to restart the system. I also appreciate you sharing the Event Viewer errors related to Intel Graphics Software. This will be very helpful in troubleshooting. To assist you more effectively, I’d like to clarify a few details:
  1. Do the freezes occur consistently with certain applications or during specific tasks, or is it random?
  2. Have you noticed any other system behaviors prior to the freeze, such as fan noise changes, unusual temperatures, or system slowdowns?
  3. Could you let us know if you’ve recently installed any new software, Windows updates, or drivers before this issue started?
  4. Are you using any external monitors or peripherals that might be connected during the freezes?
  5. I've reviewed the steps you've already taken as outlined in this thread. To build on that foundation, what other troubleshooting approaches have you tried?
Once I have this information, I can conduct further analysis and provide the next best troubleshooting steps to resolve the issue. I’ll also keep you updated throughout the process to ensure a smooth resolution.
Have a nice day!
Von M.
VonM_Intel
Hello zmeu18041,
Von M.
zmeu18041
VonM_Intel
Hello zmeu18041,
Thank you for the update. That's a solid find on your end. It’s great to hear that disabling RGB Fusion in the Gigabyte Control Center has stopped the crashes. Software conflicts like this can definitely cause unexpected system behavior, and your troubleshooting steps point strongly in that direction.
Thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, I will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel.
Von M.
