Sometimes I get following event alert:
ID 4101
Display driver igfx stopped responding and has successfully recovered.
ID 9010
A request to disable the Desktop Window Manager was made by process (4).
ID 9013
The Desktop Window Manager was unable to start because composition was disabled by a running application.
OS: Win7x64 w. SP1
BIOS v0053
Graphic Driver: 10.18.10.3345
I hope the attchment will help the developer to fix the bug.
Hello TheUndertaker,
I am sorry to hear you are having problems but let me help you.
Thanks for the information. I see you have updated the bios and the graphics driver but. Based on that, there are a few steps I want you to try such as testing a different driver version (previous) or if this issue happens when using a different Operating System.
Besides this, can you please let me know if there is any specific path to replicate the problem?
Hello Kevin,
Previous graphics driver cause also the issue.
When Monitor switching from power safer mode to active mode cause the issue.
Monitor type: HP LP2275w
Current BIOS Video Settings:
Integrated Graphics Device
IGD Minimum Memory <1 GB>
Primary Video Adaptor
IGD Primary Video Port
IGD Secondary Port
No Video Detected Error Beeps
Intel Graphics Performance Analyzers
All-in-One Chassis
IGD Flat Panel
Screen Brightness
Thanks for the information. We have released a newer driver. Please download it and install it at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23639 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23639
If issue persists, please post your graphics report and dxdiag report here.
How to get it?
Dxdiag Report: Type dxdiag in Start Menu> open> Save> Copy/Paste here.
Graphics Report: Right click on desktop> Graphics Properties> Options> Drop Down Menu> Information Center> Save> Open .txt file created> Copy/Paste here.
![](/skins/images/48A1642489FEF8D34D940AC6791CBDC2/responsive_peak/images/icon_anonymous_message.png)
