22657 Discussions
DXGI_ERROR_DEVICE_REMOVED - Intel Iris Xe Graphics
scarfoj
I am repeatedly getting the error message DXGI_ERROR_DEVICE_REMOVED when playing Command and Conquer Remastered. This is not a terribly graphics intensive game, and should be well within the capabilities of my machine. Here are the specs:
HP Spectre x360
11th Gen Intel Core i7 1165G7 2.80 GHZ
16GB Ram
Iris Xe graphics
The game runs flawlessly with no framerate issues or other performance problems, until it crashes. It generally crashes when loading a game, hitting "esc" to summon a menu, or any other pause or transitory state in gameplay.
The error message is "DXGI_ERROR_DEVICE_REMOVED"
I've tried every solution presented online, including registry edits, manually reducing performance in the intel graphics app, multiple driver updates/rollbacks, and a fresh installation of windows. I'm at my wits end.
AndrewG_Intel
Hello all,
Thank you for your patience in this matter
We would like to inform you that we tested the game for many hours. It worked just fine, and also we tried different things to pause it but we were unable to replicate this issue.
We used a Dell* Inspiron 7706 with 11th Generation Processor and Intel® Xe Graphics.
At this point, our recommendation is to check with the game developer to see if they have additional suggestions and debugging.
Andrew G.
AndrewG_Intel
Hello all,
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
Shaq
The problem is most assuredly still here. I'm slowly reaching out to petroglyph games and eventually will reach out to EA games soon if this isn't resolved. It only seems to be a problem with the iRIS Xe. I know you guys said you tested this problem, but I'm not sure if it was with the equivalent processor.
Shaq
Also, if you guys could keep this forum open a little longer, that would be great as I'm directing the developers to here so they can see the issue, and if more people keep bringing it up, that would be helpful to draw more attention to it since it only seems to be happening to iRIS Xe users.
PIERO87
 Operating System    Microsoft Windows 10 Pro
    Central Processor    Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
    User Name    piero
    Video Adapter    Intel(R) HD Graphics 4600
    Video Memory    1.0 GB
    Screen Resolution    1600 x 900
 Storage
    Total Memory    14.9 GB
    Free Memory    10.0 GB
    Total Hard disk    929.9 GB
    Free Hard disk    108.4 GB
 I/O
    Mouse    USB Input Device
    Keyboard    USB Input Device
Top
Operating System
 Computer System
    Computer Name
    User Name
    Organization    NULL
 Operating System
    OS Name    Microsoft Windows 10 Pro
    OS Version    10.0.19042
    Product ID
    System Up Time    5/25/2021 3:12:15 PM
    Internet Explorer Version    11.630.19041.0
    Microsoft DirectX Version    DirectX 12
    OpenGL Version    10.0.19041.546 (WinBuild.160101.0800)
 Registry
    Maximum Size    4095 MB
    Current Size    131 MB
    Status    OK
Top
Processor & Motherboard
 Central Processor
    CPU Name    Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
    Number of logical processors    8
    Code Name    N/A
    Manufacturer    GenuineIntel
    Current Clock Speed    3601 Mhz
    Max Clock Speed    3601 Mhz
    Voltage    1.2V
    External Clock    100 Mhz
    Serial Number
    CPU ID    Intel64 Family 6 Model 60 Stepping 3
    Socket Designation    SOCKET 1150
    CPU Internal L1    256 KB
    CPU Internal L2    1024 KB
    CPU Internal L3    8192 KB
 Motherboard
    Model    Q87M-E
    Manufacturer    ASUSTeK COMPUTER INC.
    Serial Number
    BIOS Name    3801
    BIOS Vendor    American Megatrends Inc.
    SMBIOS Version    3801
    BIOS Date    3/22/2019
 BIOS Features
    PCI is supported    Yes
    APM is supported    Yes
    BIOS is Upgradable (Flash)    Yes
    BIOS shadowing is allowed    Yes
    Boot from CD is supported    Yes
    Selectable Boot is supported    Yes
    BIOS ROM is socketed    Yes
    EDD (Enhanced Disk Drive) Specification is supported    Yes
    Int 13h - 5.25 /1.2MB Floppy Services are supported    Yes
    Int 13h - 3.5 / 720 KB Floppy Services are supported    Yes
    Int 13h - 3.5 / 2.88 MB Floppy Services are supported    Yes
    Int 5h, Print Screen Service is supported    Yes
    Int 9h, 8042 Keyboard services are supported    Yes
    Int 14h, Serial Services are supported    Yes
    Int 17h, printer services are supported    Yes
    ACPI supported    Yes
    USB Legacy is supported    Yes
Top
Memory Device
 Memory Resource
    Used Memory    4.8 GB
    Free Memory    10.0 GB
    Memory Usage    32%
 Physical Memory
    Memory Bank    BANK 0
    Description    Physical Memory 0
    Device Locator    ChannelA-DIMM0
    Capacity    4.0 GB
    Speed    1600 Mhz
    Manufacturer    Hynix/Hyundai
    Data Width    64 bit
    Memory Type    EISA
    Form Factor    DIMM
 Physical Memory
    Memory Bank    BANK 1
    Description    Physical Memory 1
    Device Locator    ChannelA-DIMM1
    Capacity    4.0 GB
    Speed    1600 Mhz
    Data Width    64 bit
    Memory Type    EISA
    Form Factor    DIMM
 Physical Memory
    Memory Bank    BANK 2
    Description    Physical Memory 2
    Device Locator    ChannelB-DIMM0
    Capacity    4.0 GB
    Speed    1600 Mhz
    Data Width    64 bit
    Memory Type    EISA
    Form Factor    DIMM
 Physical Memory
    Memory Bank    BANK 3
    Description    Physical Memory 3
    Device Locator    ChannelB-DIMM1
    Capacity    4.0 GB
    Speed    1600 Mhz
    Manufacturer    Micron
    Data Width    64 bit
    Memory Type    EISA
    Form Factor    DIMM
Top
Drives
 Disk Drives
    Name    TOSHIBA MQ04ABF100
    Media Type    Fixed hard disk media
    Capability    931.5 GB
    Interface Type    SCSI
    Partitions    4
    Total Cylinders    121601
    Total Heads    255
    Total Sectors    1953520065
    Total Tracks    31008255
    Tracks Per Cylinder    255
    Bytes Per Sector    512
    Sectors Per Track    63
    S.M.A.R.T Support    Yes
 Disk Drives
    Name    USB Device
    Media Type    Removable Media
    Capability    7.2 GB
    Interface Type    USB
    Partitions    1
    Total Cylinders    946
    Total Heads    255
    Total Sectors    15197490
    Total Tracks    241230
Top
Display
 Video Adapter
    Name    Intel(R) HD Graphics Family
    Video Processor    Intel(R) HD Graphics Family
    Manufacturer    Intel Corporation
    Video Architecture    VGA
    DAC Type    Internal
    Memory Size    1.0 GB
    Memory Type    Unknown
    Video Mode    1600 x 900 x 4294967296 colors
    Current Refresh Rate    60 Hz
    Driver Version    20.19.15.5171
    Driver Date    11/4/2020
 Monitor
    Name    Packard Bell Viseo 200Ws
    Screen Height    900
    Screen Width    1600
    Status    OK
Shaq
Did you ever find a solution?
scarfoj
Shaq,
No luck for me either. I reached out to Petroglyph and havent heard a thing back. Have you had any luck?
Shaq
I've reached out and gotten a couple of responses via Facebook. I got one email back to them, they said they were looking into it, but they too are having a tough time replicating it. They take forever to respond, but I recommend them through social media and email. I have a feeling since we are a very small lot of people having this problem, it won't get pushed through.
Farmersan
I would just like to say I´m having the same problem and was happy to find this topic but there is no solution. Any news on this or a new driver coming? I've followed the steps here and the problem persists.
Shaq
UPDATE: POSSIBLE SOUTION
I had reached out to the game devs, and though it took some time, they also reached out to Intel and apparently Intel finally managed to replicate this problem.  At the time of this update, I haven't tried it yet, but they released new drivers:
(https://www.intel.com/content/www/us/en/search.html?ws=text#t=Downloads&layout=table&cf:Downloads=[%7B%22actualLabel%22%3A%22Graphics%22%2C%22displayLabel%22%3A%22Graphics%22%7D])
As I said, I haven't tried them yet, but this is the most recent solution, so give it a try as I'm about to as well. I'll post up if it was a success for me. Let us know if it helps you guys so I can let the game devs know they can close.
Shaq
Bear in mind, they still consider it BETA as the release was only a few days ago.
MaddenJMF
INFO FOR TROUBLESHOOTING & INVESTIGATION  - NO SOLUTION BELOW
Same issue on Dell Inspiron 16 Plus with Intel 11800H 11th Gen UHD Integrated graphics. 16GB ram. Laptop itself has an odd 3k resolution - LIGHTBULB MOMENT, OP also has 3K display maybe that’s the answer right there. It’s new. Your test machine has common QHD resolution and it works just to note. I WILL CHANGE MY RES SETTINGS ON MACHINE TO SOMETHING TYPICAL, TEST AND REPORT BACK ON THIS.
UPDATE ON ABOVE: System resolution changes made no difference.
The whole point of me signing up and posting this is to try and find some connection between all of these people having the same issue as me. The time I’ve put into this is driving me crazy.
Windows 11 Pro x64
https://www.intel.com/content/www/us/en/products/sku/213803/intel-core-i711800h-processor-24m-cache-up-to-4-60-ghz.html
I do not have dedicated Nvidia graphics.
Interestingly, I can run this game no problem on a 9 year old i3 (Windows 10 Home) with only integrated graphics. The processor falls just outside of Windows 11 requirements. I upgraded the HDD to SSD and increased ram capacity to 8GB. It’s not throttling or crashing. Albeit a little slow when there’s a ton of units on screen at once after having built a mega army. Still playable throughout.
For attention of Intel moderators, my wife has the same laptop you did your tests on with nvidia GTX (7706 2 in 1). Did yours also have dedicated graphics? I have not tried to run the game on hers but suspect it would work.
I can replicate this and would love to work with you (such as remote support) to demonstrate.
I have tried:
- Manually adding and enabling windows high performance power plan
- Set best performance in Windows 11 settings
- Experimented with TDR
- Added game .exe to Windows 11 game mode and set as Best performance
- Full uninstall if drivers using DDU
- Tried with manufacture recommended Intel drivers
- Tried with latest generic drivers
- Turned off game mode to try prevent background processes from being terminated to speed up game performance
- Experimented with in game resolutions, vsync, and antialiasing in Intel control panel
- Removed my dual setup monitor (tested with and without additional display using HDMI input)
- I looked to adjust 3D stereoscopic settings in Windows 11 but the setting isn’t present despite coming up in settings search
- Investigated hardware acceleration settings to no avail
The latest DCH drivers do not support the old embedded Intel control panel that was also found in system tray and context menus (on desktop) - It’s now all done through a UWP store app that seems to be far more limited on options.
I think it could be an issue present for machines without dedicated graphics card, but our processors, especially Xe should handle the game.
THIS ONE PARAGRAPH MAY BE MORE FOR GAME DEVELOPERS BELOW - SKIP PAST IF NECESSARY:
Sometimes, in the menus, the background doesn’t properly render and displays a “gold Petroglyph logo on a white background”, as the background. In game, individual units randomly render in this way. This is when I know it will crash. This shows up also in the “Jukebox” settings menu in game.
As this begins to occur, if I exit game (playable area) and exit to menu, the crash can occur. It also occurs like clockwork in lobby menu, upon clicking Join/Host buttons - Sometimes the rendering is fine. If I successfully get a game going, and don’t navigate settings menus, I may finish a game until I exit to lobby. Other times it will spontaneously crash.
It’s not specifically a Dell issue. It’s not necessarily an Intel issue for older machines. There is either an issue in the game, responsibility of Petrogylph/EA and/or an issue with 11th Gen Intel processors/drivers, perhaps without dedicated graphics, and possibly in conjunction with windows power management.
I welcome being reached out personally for assistance with this to help the community towards a resolution.
MaddenJMF
MaddenJMF
  • UPDATE
    A fix may be on the way, as per a post I made on EA forums. I mentioned a reply I received from Petroglyph support. I’ve copied and pasted my what I shared there below:
    “I've actually received a reply direct from Petroglyph (email support) and and a game update/patch appears to be in the final stages before release! This was on June 9th, 2022.
    It will be pushed through Steam as normal. It sounds like if final testing doesn't produce any issues, this could occur fairly soon.
    This is very exciting news 😁
    Seems like it is affecting 11th Gen Intel processors with certain configurations, but there’s something in the games design itself that’s not pointing properly. From what I’ve found, DXGI errors are occurring for other games across the internet too, and in most cases it seems to relate to Nvidia of which I don’t have on my laptop. It’s affecting people with Iris XE and Intel UHD integrated graphics.
A recent Windows cumulative update addressed an issue with DX9 and I thought that may have fixed it, but I’m not sure what version of DirectX the game needs. I still experienced the same issues after the Windows update.
GraphicsExpert
This is still an issue.  I've tried the DCH, Arc DCH, and HP drivers.  No luck.
The only driver that works is the Microsoft Basic Display Adapter.  This is the fallback when the HP/Intel graphics adapter is Disabled in Device Manager.
Questions for the Intel Technicians:
  • Were you actually playing the game or letting the game sit for hours?  In order to generate the error you need to play the game or hit ESC and go into the menu a bunch of times.
  • What version of game and graphics driver were you using?
  • What size display were you using?  Try 1920x1200 or higher external display over HDMI.  You may not see the issue as much with smaller display sizes since lower resolutions require less graphics memory.
  • Which Windows OS/DirectX were you using?  Windows 10 and Windows 11 use different versions of DirectX.  In Windows 11, DirectX 12 Ultimate shows up as "Disabled" in DxDiag.
Blackhawk84
I've just buy this game too today and I still have the same issue with my HP Envy laptop (intel core i7 and Intel Iris xe graphic chipset).
As something has been done on this topic since last answer ?
