22775 Discussions
Deleting Registry Keys
_xReTr0_
Hi, I was downloading a Driver but every time I download it, it says it's deleting some registry keys during the setup progress. It then says Setup Failed to install one or more drivers. Can I please get a solution.
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
_xReTr0_
_xReTr0_
Alberto_Sykes
_xReTr0_, Thank you for posting in the Intel® Communities Support.
Based on the information of the SSU report, it shows the Graphics driver currently installed as version 1.7.128.0 which doesn't line up with the Intel® official driver's nomenclature.
Just to let you know, we always recommend to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them to work with your specific platform.
I looked in HP's web site and the latest Graphics driver they have available is version 27.20.100.8280 Rev.S, please try a clean installation of that driver following the instructions in the links below and once you get the chance, please let us know the results:
https://support.hp.com/ie-en/drivers/selfservice/swdetails/HP-14-ck0000-Laptop-PC/20395790/model/23116120/swItemId/ob-253251-1
Albert R.
_xReTr0_
what do i do if it now says Info,
Target Path : c:\SWSetup\sp104245\
Info, Execution : c:\SWSetup\sp104245\install.bat
on the c:\SWSetup\104245\install.exe
Stefan3D
"Based on the information of the SSU report, it shows the Graphics driver currently installed as version 1.7.128.0 which doesn't line up with the Intel® official driver's nomenclature."
That number is actually mentioned in eg latest release notes:
CONTENTS OF THE PACKAGE:
•Intel®Graphics Driver
•Intel®Graphics Driver Installer (1.7.128)
@_xReTr0_
In Explorer navigate to c:\SWSetup\sp104245\ and double-click install.bat
_xReTr0_
It says the driver is not supported on this OS version
