23083 Discussions
Device PCI\VEN_8086&DEV_9BC8&SUBSYS_0A4C1028&REV_03\3&11583659&1&10 had a problem starting.
MonteK
intel video card uhd 630 is not working properly does anyone know how to fix it?
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Waiting for Windows 12]
MonteK
Enclosed is the file that I just ran what do I do next?
MonteK
Did you look at the file that I uploaded?
David_G_Intel
Hello MonteK
Thank you for posting on the Intel️® communities. Please share with us the following information:
  • When did this issue start?
  • Did it happen with previous driver versions?
  • Did you test other drivers?
  • Does this happen with both Dell and Intel drivers?
David G
MonteK
Issue started before I got the computer
Yes
What other drivers?
Yes
David_G_Intel
David G.
MonteK
Yes
What other drivers?
Yes
MonteK
David_G_Intel
Thank you for your response, please list the driver versions you tested to try to reproduce this problem on our side. If you tried other drivers, did you use a clean installation method?
David G.
David_G_Intel
David G.
MonteK
David_G_Intel
As a friendly reminder, please provide driver versions you tested to try to reproduce this problem on our side. If you tried other drivers, please confirm if you used a clean installation method.
David G.
MonteK
This video card has issues and has had for years why do you still sell it?  There are reports all over the internet about it
MonteK
This video card has issues and has had for years why do you still sell it?  There are reports all over the internet about it.  Does anyone have a fix for this issue?  Can someone look at the attached txt file
MonteK
https://www.intel.com/content/www/us/en/support/intel-driver-support-assistant.html
can  someone click on this and let me know if there is a way to fix this video card
David_G_Intel
Thank you for the report, as you can see it seems to be a driver corruption. Two different graphics drivers show as installed on your system, please follow these steps to reinstall the correct driver:
After you complete the steps let us know if the issue persists.
David G.
David_G_Intel
David G.
David_G_Intel
David G.
