22878 Discussions
Device not started in intel properties under event
Ammy
I have updated my driver to the latest one. However, when I go to the display adapters, it says that device not started even though the device status said that this device is working properly. Screenshot 2021-11-25 144420.jpg
David_G_Intel
Hello Ammy
Thank you for posting on the Intel️® communities. Please share with us the following information:
  • Do you get any graphics related issues after that?
  • Did you test other drivers?
  • When did this issue start?
  • Which Windows version do you use?
  • Intel® System Support Utility (Intel® SSU) results
David G
David_G_Intel
Hello Ammy
David G
David_G_Intel
David G.
Ammy
Hello, thank you for the reply. My OS is windows 11. I thought that was the problem since I have only recently update my windows 10 to windows 11. But then after reinstall it back and update my intel driver, the same problem happened again. So now I reinstall my windows again and this time, I did not update my intel driver. I didn't follow in the previous post since I did this before your comment. I'm not sure whether or not I should update my driver now because I'm afraid the same thing might happen again.
David_G_Intel
As a friendly reminder, please share with us the following information to help you resolve this request:
  • Did you test other drivers? Please list their versions
  • Which specific driver version started this?
  • Is this a desktop or laptop system? Is a custom build?
  • If not, what is the model of the system?
  • Which driver version do you use right now?
The Intel SSU doesn't change anything on your system, it just lets us know more information about it to provide the appropriate drivers or other recommendations. Let us know if this issue is resolved, if you have any questions or if the issue persists.
David G.
David_G_Intel
Hello @Ammy
David G.
David_G_Intel
David G.
