22689 討論
DirectX 12 on Fortnite no longer supported on Intel graphics because of UE 5.1
Xillvion
新貢獻者 II
49,822 檢視
With the new map update to Fortnite, DirectX 12 no longer works on Intel Iris Xe graphics because of Unreal Engine 5.1, says that "DX12 is not supported for your system" if you try to force it via command line arguments.
DX11 and Performance mode works fine but "performance mode" performance still feels absymal compared to 10th gen Intel UHD graphics.
Since this is a problem with UE 5.1, I want to know if the GPU is capable of supporting it.
24 回應
AlHill
超級使用者
45,467 檢視
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Xillvion
新貢獻者 II
45,420 檢視
Here's the SSU info and the screenshot of the error message:UE5.1_DX12_error.png
DeividA_Intel
員工
45,366 檢視
Hello Xillvion,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Iris® Xe Graphics.
In order to better assist you, please confirm the following:
1. Does the game work with DX11?
2. Did you use to play Fornite with DX12 before the error?
3. Did you get the error as soon as the game was updated?
Deivid A.
Xillvion
新貢獻者 II
45,348 檢視
  1. Yes, but doesn't provide good framerates.
  2. Somewhat, before that update, DX12 shader compilation was fine but later became worse with each small updates, before becoming unplayable.
  3. Of course.
I actually tried out the Unreal Engine 5.1 Editor a day before the game got updated, and the same thing happens. Create a new project, change the rendering settings to DirectX 12 and the same error message will show up trying to open the created project...it probably means that every future UE 5.1 games (if it's playable enough) will have the exact same issue.
Here's the screenshot the message for changing to DirectX 12 in-game though:
Xillvion
新貢獻者 II
45,340 檢視
Also, I tried using the Arc graphics driver, same DX12 error message but no problems with any DX11 or other DX12 games.
But the beta version of the Arc driver will cause the game to become corrupted a bit, freeze for few seconds and then crash when in DirectX 11. Screenshot: crash.png
The_Electrinix
初學者
45,285 檢視
Hi Xillvion,
The DirectX 12 problem in Fortnite is generated due to the Lack of support for the SM6 Feature Level.
Screenshot of FortniteGame.log:imagen.png
As a result, the game will not open
SM6 Feature Level is the support for the graphics card to use the features of DirectX 12, (like DirectX 12 Ultimate or RTX), just because it says it does not support the SM6 Feature Level does not mean that your graphics card does not support DirectX 12, it means it does not support all the features that this brings, and it is very commoner than you think because almost all Integrated graphics do not support Ray Tracing, or do not support the Shader Model, or whatever it needs.imagen.png
And as you can see in this screenshot extracted from the Unreal Engine Documentation Page
(https://docs.unrealengine.com/5.0/en-US/API/Runtime/RHI/ERHIFeatureLevel__Type/)
It asks for all those requirements to be compatible with SM6 Feature Level due to Nanite and Lumen that requires them, I know that DirectX 12 had generally better performance and I think Epic in this case should have a switch in the game settings to enable or disable them and let use only the DirectX 12 without that features as DirectX 11.
I hope it has helped you
By the way, I'm not affiliated with intel
Pd: the FortniteGame.log can be found at (C:\Users\%UserProfile%\AppData\Local\FortniteGame\Saved\Logs)
If someone knows how to bypass the SM6 Feature Level, will really appreciate it. Want to test. 🙂
Xillvion
新貢獻者 II
45,270 檢視
Wow, I didn't even think of checking the game logs when that happened.
So that explains the same error message I got in Unreal 5.1 editor, a day before Fortnite upgraded the engine.
Thanks for looking into it.
Unfortunately, it just probably means the game is not recommended for Iris Xe graphics, since I and someone else reported a problem with performance mode months ago and yet still no mention of any fixes for it.
Harryincorrect
新貢獻者 I
45,197 檢視
That someone else would be me xD. Came here for a fix to this same problem and voila, we meet again lol. Btw performance mode works okay now. Just wanted to see the graphics changes without any stuttering which directx 11 doesn't allow.
DeividA_Intel
員工
45,184 檢視
Hello Xillvion,
Thank you for the information provided
Deivid A.
dasfox
初學者
44,950 檢視
I'm having problems too. I used to run DirectX12 on my laptop.
11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz 2.80 GHz
16.0 GB (15.6 GB usable)
Windows 11 22H2
Intel Iris XE Graphics
But there's been an update and the game doesn't let me select DirectX 12 anymore. I can only select DirectX 11 and performance mode with warnings.
Both DirectX11 and performance mode are way glitchy. DirectX 12 used to crash every once in a while but atleast the game play was smooth so that was the preferred option.
I have every possible setting turned off or low and gameplay is now terrible. My internet connection is the same. We have another device running fortnite, a nintendo switch, and it's not having problems so it's not the connection. All I can say is I can't run directX 12. is this something I'm going to have live with?
Dissappointing I can't run fortnite on this laptop. It's a Intel NUC M15. I thought it would be powerful enought.
Eli3
初學者
30,159 檢視
Me ha pasado lo mismo, tengo un i3-1115g4 de 4.1Ghz, imposible que vaya bien. No es cosa de Intel, porque muchos juegos de la misma exigencia me van bien... Es cosa de Fortnite, por lo que lo mejor es proceder con el reclamo en la plataforma de Epic Games. En teoría el modo "Rendimiento" está diseñado para PC lowspecs, pero según la temporada el rendimiento del juego cambia: Aumenta o disminuye incluso en PC gamer.
En modo rendimiento, la iGPU a 100% de escalado con 60fps consume máximo 70%, mientras que el CPU se cuelga constantemente a 99%. Esta temporada, el juego simplemente es injugable, pero la temporada pasada hacía hasta streaming... Todo va según lo optimizada que esté la actualización.
Creo que los usuarios de hardware intel para laptops debemos descartar la idea de jugar Fortnite hasta que Intel haga una colaboración con el juego y agreguen unos preajustes personalizados para sus clientes.
DeividA_Intel
員工
44,842 檢視
Hello Xillvion,
Thanks for your patience. As a test, try the Arc driver version since this includes a patch "Intel® Game On Driver support on Intel® Arc™ A-series Graphics for Fortnite (Chapter 4/UE5.1)*"
Please, let me know the outcome.
@dasfox, Thanks for your report. Feel free to try the steps shared here or you can open a new thread to get support.
Deivid A.
Xillvion
新貢獻者 II
44,826 檢視
I have already tried using 31.0.101.3959 before you replied and it still has the same problem as the beta version where the game will crash in DirectX 11. Someone already reported the issue here:
https://community.intel.com/t5/Intel-ARC-Graphics/intel-arc-driver-version-31-0-101-3959-is-not-working-in/m-p/1437497
I also tried installing 31.0.101.3975 BETA , still the exact same problem.
DeividA_Intel
員工
44,760 檢視
Hello Xillvion,
Thanks for the confirmation, I really appreciate it. I will proceed with the investigation to find a solution to this issue. As soon as I have any information I will let you know.
Deivid A.
tristan4
初學者
44,596 檢視
hi i have the same problem but what can i do?
DeividA_Intel
員工
43,417 檢視
Hello Xillvion,
Thanks for your patience. I would like to let you know that a bug report (ID 1309536736) has been submitted, I cannot promise any fix anytime soon but if there is one we will note it in the community thread and in future driver release notes.
Since this issue is being investigated and we will update the thread with the outcome, let me know if is fine to close this thread.
Deivid A.
Xillvion
新貢獻者 II
43,357 檢視
The same ID as the one @Harryincorrect reported last year? Also, the 31.0.101.4032 driver no longer crashes the game but the shader compilation doesn't work, which has been like that since 2020.
Whatever it is, yes, you can close the thread.
DeividA_Intel
員工
43,330 檢視
Hello Xillvion,
Thanks for the confirmation. We will update the thread with further information if needed.
I will proceed to close this thread, thanks for your comprehension.
Deivid A.
Harryincorrect
新貢獻者 I
43,077 檢視
Would you mind explaining why both this issue and another issue have the same id?
Arbazz
初學者
42,708 檢視
man... having the same problem. the game used to run so fine before the launch of launch of fortnite chapter 4. used to get around 120 fps in dx12 but now it lags so bad even on performance mode. i have stopped playing the game due to this issue..so sick of epic games.
回覆
