22885 Discussions
Disable automatic updating of Intel ARC
78bakalit
If I install the graphics driver without the Arc software, it works.
If the Internet is connected, Arc is simply installed automatically.
If Arc is already installed, it will be updated, which I don't want.
All updates are disabled on the computer, i.e. Windows 11 23H2.
I want the computer without any additional software,
just the driver and decide for myself if I want to update it or not.
Mike_Intel
Hello 78bakalit,
  1. What is the model of your Graphics Controller?
  2. Can you tell me the reason why you don't want to install the Arc Software?
  3. Are you using a laptop? Can you provide the brand and model of your system?
Michael L.
78bakalit
01. I have an i7-12700K.
02. I don't need the Arc software because Premiere Pro and the Media Encoder and
Photoshop control the driver directly.
I only installed the driver, without any software, but when you plug in the internet,
it downloads the Ark software. I want to decide for myself whether I want that or not.
03. I have a self-built system, i7-12700K and PRO Z690-A, desktop.
78bakalit
I install the computer and don't do any updates if everything is working fine,
but when I update something always goes wrong. I want to keep the same software.
I'll reinstall everything at a later date.
Certifiedlover6
try clean unistalling the driver with the ddu program (in safe mode). check the box in the settings tab that prevents windows from searching for hardware drivers then uninstall and restart in normal mode, then download the driver of ur choice for ur card and choose custom installation instead of express, it will give u the option to install only the driver without the intel arc control,
Mike_Intel
Hello 78bakalit,
Thank you for for the update.
Let me just check, have you tried the recommendation of the other forum user on how to remove the application during installation?
Michael L.
78bakalit
I just installed the driver without any software, when you plug in the internet
it automatically installs the ARC.
Mike_Intel
Hello 78bakalit,
For me to have this checked, kindly generate the SSU logs of your system by following the steps here:
Michael L.
Mike_Intel
Hello 78bakalit,
Michael L.
78bakalit
Hello, I've tried everything with the driver, but it doesn't work because it's faulty,
it won't work until Inter has fixed the error. I found a craft solution:
My Video: https://www.youtube.com/watch?v=JH03PMYZQko
Mike_Intel
Hello 78bakalit,
Thank you for the update.
Please help generate the SSU logs for me to further check this request.
Michael L.
78bakalit
Hello, you can install it yourself, the result will be the same,
it doesn't matter which computer you install it on.
Mike_Intel
Hello 78bakalit,
That is why I am trying to gather more details like the SSU for me to understand your set up and simulate it here in our lab.
Michael L.
Mike_Intel
Hello 78bakalit,
Michael L.
78bakalit
Hello, I saw the posts, I installed the driver for myself like in the video, I hope that Intel will improve it.
Mike_Intel
Hello 78bakalit,
Can you tell me what is that video for me to also check and review?
Michael L.
78bakalit
Mike_Intel
Hello 78bakalit,
Thank you for sending the video however I am still waiting for the SSU logs that I requested for further investigation of the issue that you reported.
Michael L.
Mike_Intel
Hello 78bakalit,
Michael L.
Mike_Intel
Hello 78bakalit,
I am sending another follow up on the information that I requested.
Michael L.
