22657 Discusiones
Display Driver Crashes
Empleados
2.728 Vistas
Hello, I have browsed all other posts about this topic and have yet to find a solution for mine, I will provide the dxdiag report, a screenshot of the error message and hope someone can help me out.
I remember looking through services.msc and disabling a few things that didn't need to be on automatic and I am not sure if this is where my problem came from but its the only thing I can think of. I have run a scan with Microsoft security tools, AVG and I have also booted into safe mode to try and narrow my problems but have had no luck.
________________________________________________________________________________________________________________________
REPORT:
System Information
Time of this report: 3/19/2013, 13:49:30
Machine name: DANNY-7
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP Compaq dc7700p Ultra-slim Desktop
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz (2 CPUs), ~2.4GHz
Memory: 3072MB RAM
Available OS Memory: 3056MB RAM
Page File: 1717MB used, 4391MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: The file mobiolawave.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) Q965/Q963 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel(R) GMA 3000
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2992&SUBSYS_2803103C&REV_02
Display Memory: 256 MB
Dedicated Memory: 0 MB
Shared Memory: 256 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: HP L1955
Monitor Id: HWP262D
Native Mode: 1280 x 1024(p) (60.020Hz)
Output Type: DVI
Driver Name: igdumdx32.dll
Driver File Version: 8.14.0010.1930 (English)
Driver Version: 8.15.10.1930
DDI Version: 9Ex
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 9/23/2009 19:14:54, 536576 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6AD2-11CF-0674-0908A3C2C535}
Vendor ID: 0x8086
Device ID: 0x2992
SubSys ID: 0x2803103C
Revision ID: 0x0002
Driver Strong Name: oem6.inf:Intel.Mfg:i965G0:8.15.10.1930:pci\ven_8086&dev_2992
Rank Of Driver: 00F42001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2...
0 kudos
3 Respuestas
DArce
Colaborador Valioso III
1.346 Vistas
Please bear in mind that this product has reached its End of Interactive Support so Intel no longer provides interactive support for this product.
I was checking on HP's web site for information on the drivers they provide for this system and I can see that there are no video drivers posted from them. Could you please confirm if this system came with that specific operating system or if it was installed later?
Something you might try would be doing a BIOS update from your computer manufacturer, available from this URL:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3232065&prodTypeId=12454&prodSeriesId=3232030&swLang=13&taskId=135&swEnvOID=2096# 120 http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3232065&prodTypeId=12454&prodSeriesId=3232030&swLang=13&taskId=135&swEnvOID=2096# 120
Empleados
1.346 Vistas
I believe this computer has been upgraded and none the less I just reinstalled Win 7 64bit last night and updated the BIOS from you link ( thank you ) and to no avail the problem still persists. I am running two monitors could that be an issue? Is the card going out? I am at a loss. Thank you for your reply and help.
DArce
1.346 Vistas
You may try swapping these other parts that you mentioned and you could also try with the operating system that was validated for this system in order to test with the drivers that are provided by Hewlett Packard* which are customized for this system. I have seen that behavior when using generic drivers which stops after using the customized drivers from the OEM.
Responder
