22892 Discussions
Display Driver has stopped responding and has recovered
Hi. I know this question has been asked many times, but many are unanswered. I have a Dell Inspiron 1545, Window 7 64 bit. Just yesterday, my laptop kept blacking out, freezes and then unfreeze and this message would pop up saying, "Display driver stopped responding and has recovered. Display driver Intel Graphics Accelerator Drivers for Windows XP(R) stopped responding and has successfully recovered." It keeps happening around every 15-30 minutes. Sometimes, it totally blacks out. Other times, it unfreeze but the windows are blank. Someone please help me. The display adapter I have is Mobile Intel (R) 4 Series Express Chipset Family." Some people said online to update it and that might fix the problem. I went to the Intel website and updated the lastest one given, but the problem is still here. I've restored my laptop to a certain restore point, but still did not solve the problem. Suggestions and ideas? Thank you a head of time.
NICHOLAS_F_Intel
@Paige: Try this driver, let me know how it goes; https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng Download Center
@KengFai: If you are still unable to open the download link above, you can either try loading the website in an alternate browser (Chrome* or FireFox*), or you can manually locate the driver. Go to downloadcenter.intel.com -> Graphics, Laptop Graphics Drivers, Mobile Intel® 4 Series Express Chipset Family -> download driver version (.exe) .2869. Let me know if you're still having issues with it.
@vinod: Try this driver, let me know how it goes; https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng Download Center
@Daryl: Try this driver, let me know how it goes; https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng Download Center
Thanks everyone,
-Nic
Hi Nic,
I installed the drivers you suggested but unfortunately the problem still persists ... could you recommend me anything else?
Thank you so much for your help!
NICHOLAS_F_Intel
@recklosh: Try this driver; https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng Download Center
@Paige: Go to the following link, and download/install the latest BIOS available for your system (Version 218). http://www.asus.com/Notebooks_Ultrabooks/K50IJ/# support_Download_30 ASUS - K50IJ Additionally, try using the ASUS* driver provided for your system (VGA -> Version V8.15.10.2021) - it may work better with your system since it is directly from your OEM. Let me know how it goes.
-Nic
Hi Nic,
Thanks for your help. Unfortunately I am getting this error when attempting to install the driver.
An error occurred while registering one or more components. Setup will exit.
Any other suggestions?
NICHOLAS_F_Intel
I would suggest doing a complete uninstall of your current display driver, and then following the have disk method. You can read about it here; http://www.intel.com/support/graphics/sb/CS-033915.htm Graphics — How to update graphics driver for Microsoft Windows 7*
-Nic
Thanks Nic,
I managed to install the driver but now it won't get past the welcome screen, getting a lot of black artifacts onscreen and then it reboots. I am typing this in safe mode. Is there anything else I can try?
hi nice,
i have a problem in display i.e flickering in dispaly can u pls give solution
Hi Nic,
I tried your suggested solutions, but I ran into the problem once again when watching videos. Could you suggest anything else to me?
Thank you so much for your help.
NICHOLAS_F_Intel
@vinod: I would be happy to provide some assistance to this issue. Can you create a new thread for this issue as it is not related to the "Display Driver has stopped responding and has reecovered" message issue? Thank you.
@Saurabh: Try this driver; https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22165&lang=eng Download Center
@Paige: Can you provide an updated copy of your dxdiag please?
-Nic
Dear Nic,
I am deeply troubled that I too am suffering the same afflictions that have griped my poor Dell Inspiron E1505.. The Display Driver has failed and has recovered but this happens often. I've been suffering also from the dreaded BSOD which I'm concerned might be an affiliated symptom of this affliction. Please help me Obi-Wan...
System Information
Time of this report: 4/22/2013, 17:34:44
Machine name: THECUDDLEFISH
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: MM061
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A13
Processor: Genuine Intel(R) CPU T2060 @ 1.60GHz (2 CPUs), ~1.6GHz
Memory: 4096MB RAM
Available OS Memory: 3318MB RAM
Page File: 2444MB used, 4190MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Mobile Intel(R) 945 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel(R) GMA 950
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_27A2&SUBSYS_01BD1028&REV_03
Display Memory: 256 MB
Dedicated Memory: 0 MB
Shared Memory: 256 MB
Current Mode: 1280 x 800 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: CPT140B
Native Mode: 1280 x 800(p) (59.969Hz)
Output Type: Internal
Driver Name: igdumd32.dll
Driver File Version: 8.14.0010.1930 (English)
Driver Version: 8.15.10.1930
DDI Version: 9Ex
Driver Model: WDDM 1.0
Driver Attributes: Final Retail
Driver Date/Size: 9/23/2009 13:18:08, 3829760 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-64E2-11CF-1274-B721A2C2C535}
Vendor ID: 0x8086
Device ID: 0x27A2
SubSys ID: 0x01BD1028
Revision ID: 0x0003
Driver Strong Name: oem4.inf:Intel.Mfg:i945GM0:8.15.10.1930:pci\ven_8086&dev_27a2
Rank Of Driver: 00F42001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
{335AA36...
Sure I can Nic. here's my updated dxdiag.
System Information
Time of this report: 4/22/2013, 23:39:42
Machine name: PAIGE-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
System Manufacturer: ASUSTeK Computer Inc.
System Model: K50IJ
BIOS: Default System BIOS
Processor: Pentium(R) Dual-Core CPU T4500 @ 2.30GHz (2 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 4062MB RAM
Page File: 3325MB used, 4794MB available
DxDiag Notes
Display Devices
Card name: Mobile Intel(R) 4 Series Express Chipset Family
Chip type: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_18621043&REV_09
Display Memory: 1695 MB
Dedicated Memory: 64 MB
Shared Memory: 1631 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Id: LGD01E8
Native Mode: 1366 x 768(p) (59.973Hz)
Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.2021 (English)
Driver Version: 8.15.10.2021
DDI Version: 10
Driver Model: WDDM 1.1
Driver Date/Size: 12/14/2009 18:26:42, 5968896 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-1674-6838A9C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x18621043
Revision ID: 0x0009
Driver Strong Name: oem12.inf:Intel.Mfg.NTamd64:iCNT0:8.15.10.2021:pci\ven_8086&dev_2a42
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend D...
Hi Nic, my Display Driver (314.22) stops working as well, here's my DxDiag, any suggestions?
Machine name: HOME-PC
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 01/28/10 13:41:45 Ver: 08.00.15
Processor: Intel(R) Core(TM) i7 CPU 975 @ 3.33GHz (8 CPUs), ~3.3GHz
Memory: 6144MB RAM
Available OS Memory: 6136MB RAM
Page File: 2470MB used, 9797MB available
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Display Devices
Card name: NVIDIA GeForce GTX 295
Manufacturer: NVIDIA
Chip type: GeForce GTX 295
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_05EB&SUBSYS_070510DE&REV_A1
Display Memory: 3684 MB
Dedicated Memory: 873 MB
Shared Memory: 2811 MB
Current Mode: 1360 x 768 (32 bit) (60Hz)
Monitor Model: 32LX2R-ZJ
Monitor Id: GSM7559
Native Mode: 1360 x 768(p) (59.799Hz)
Output Type: HD15
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.1422 (English)
Driver Version: 9.18.13.1422
DDI Version: 10
Driver Date/Size: 3/15/2013 06:53:06, 17990800 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-46AB-11CF-E076-08271CC2C435}
Vendor ID: 0x10DE
Device ID: 0x05EB
SubSys ID: 0x070510DE
Revision ID: 0x00A1
Driver Strong Name: oem82.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section002:9.18.13.1422:pci\ven_10de&dev_05eb
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5...
if u have verified your drivers are correct and all the setting are optimal then it could be even the heat problem or insufficient power to the display adapter. have u tried recording the temperature of the adapter. try using a cooling pad to fend off the heat. .also try different setting from the in game option menu
hope it helps
Hi Nic,
I posted my updated dxdiag above, do you have any further recommendations for me?
Thank you so much.
Hi Nic,
This is my dxdiag:
System Information
Time of this report: 5/1/2013, 10:20:43
Machine name: MYCOMPUTER-PC
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
System Manufacturer: Hewlett-Packard
System Model: HP Compaq 6000 Pro MT PC
Processor: Intel(R) Core(TM)2 Duo CPU E7600 @ 3.06GHz (2 CPUs), ~3.1GHz
Memory: 4096MB RAM
Available OS Memory: 3992MB RAM
Page File: 3939MB used, 4041MB available
User DPI Setting: 120 DPI (125 percent)
DxDiag Notes
Display Devices
Card name: Intel(R) Q45/Q43 Express Chipset (Microsoft Corporation - WDDM 1.1)
Chip type: Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2E12&SUBSYS_3048103C&REV_03
Dedicated Memory: 32 MB
Shared Memory: 1663 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor Model: DELL E197FP
Monitor Id: DELA024
Native Mode: 1280 x 1024(p) (60.020Hz)
Output Type: HD15
Driver File Version: 8.15.0010.1749 (English)
Driver Version: 8.15.10.1749
DDI Version: 10
Driver Date/Size: 7/13/2009 19:41:07, 5437952 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-6D52-11CF-5975-4210A3C2C535}
Vendor ID: 0x8086
Device ID: 0x2E12
SubSys ID: 0x3048103C
Revision ID: 0x0003
Driver Strong Name: igdlh.inf:Intel.Mfg.NTamd64...1:iEGL0:8.15.10.1749:pci\ven_8086&dev_2e12
Rank Of Driver: 00EC2001
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProces...
NICHOLAS_F_Intel
@Jennifer: You're currently using our latest drivers for your system, however when I checked your OEM to see if they had an alternate version you could try, I found that they do not support your system with Windows* 7... Vista & XP is what your system can handle. I would recommend contacting your OEM and seeing if they have an alternate solution for you.
@Paige: At this point, you've updated your drivers with both Intel® as well as Asus* versions. Your BIOS has been updated, and you don't have an add-on graphics card that would be causing issues either... It might not be a bad idea to re-install your operating system. However, unlike operating system re-installs in the past, Windows* 7 is a relatively quick installation (takes about 20 mins after its launched).
@djt7000: You have an NVidia* card.. I would recommend contacting them for support.
@Kareem: Can you provide a copy of your DxDiag please? (Start -> Run -> dxdiag -> Save All Information). Thanks.
@topedge: Try this driver; https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng Download Center
Thanks all,
-Nic
NICHOLAS_F_Intel
@Paige: In order to further assist you in re-installing your operating system, I would like to recommend a service I use on my own system at home. It's called ninite.com (there are other alternatives to this website out there, but this is the only one I've tried out). Just checkbox the applications you want installed (make sure you select Java* by default) and choose the "download installer" button on the bottom of the page. It will provide an individual installer file that will install all the applications for you.
Again, this is my own personal recommendation based off my personal experience working with it.
EDIT: You will still need to install your system drivers though. Those should have been provided by your OEM on a CD (or as part of your OS install CD) - as well as our latest graphics drivers, those aren't included when you use the above service.
-Nic
Hi Nic,
I too am having problems with this driver issue. Could you please help?
Here is my dxdiag:
System Information
Time of this report: 5/2/2013, 20:52:26
Machine name: JAWAD-PC
Operating System: Windows 7 Professional 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
System Manufacturer: SAMSUNG ELECTRONICS CO., LTD.
System Model: R519/R719
BIOS: Phoenix SecureCore(tm) NB Version 08CI.M055.20100210.JIP
Processor: n/a
Memory: 2048MB RAM
Available OS Memory: 2008MB RAM
Page File: 2141MB used, 1876MB available
DxDiag Notes
Display Devices
Card name: Mobile Intel(R) 45 Express Chipset Family (Microsoft Corporation - WDDM 1.1)
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_C059144D&REV_09
Display Memory: 780 MB
Shared Memory: 748 MB
Monitor Id: INL0005
Native Mode: 1366 x 768(p) (60.053Hz)
Driver Name: igdumd32.dll,igd10umd32.dll
DDI Version: 10
Driver Date/Size: 7/14/2009 02:15:31, 3805184 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-2871-53E0A9C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0xC059144D
Revision ID: 0x0009
Driver Strong Name: igdlh.inf:Intel.Mfg.NTx86...1:iCNT0:8.15.10.1749:pci\ven_8086&dev_2a42
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV...
Thank you very much Nic. You were very helpful. looks like I'll have to start over on my computer after all, but I'm glad I got your advice beforehand. Thanks again!
