22923 Discussions
Display Driver has stopped responding and has recovered
Hi. I know this question has been asked many times, but many are unanswered. I have a Dell Inspiron 1545, Window 7 64 bit. Just yesterday, my laptop kept blacking out, freezes and then unfreeze and this message would pop up saying, "Display driver stopped responding and has recovered. Display driver Intel Graphics Accelerator Drivers for Windows XP(R) stopped responding and has successfully recovered." It keeps happening around every 15-30 minutes. Sometimes, it totally blacks out. Other times, it unfreeze but the windows are blank. Someone please help me. The display adapter I have is Mobile Intel (R) 4 Series Express Chipset Family." Some people said online to update it and that might fix the problem. I went to the Intel website and updated the lastest one given, but the problem is still here. I've restored my laptop to a certain restore point, but still did not solve the problem. Suggestions and ideas? Thank you a head of time.
Nic
Thanks a lot for your response.I will try this.
I have one query the issue which I am facing is it an hardware issue?
Hi Nic
Do i need to remove old Display drivers ? Or can i directly install these new drivers please help on this.
NICHOLAS_F_Intel
It shouldn't matter if you choose to delete them or not (there are always "default" drivers in case you run into an issue and need to remove them via safe mode). I would say yes, because the old drivers were causing you issues (referring to your Win7* system as Vista*).
-Nic
I have downloaded drivers from the link you have provided.
When i run that .exe file it is extracting into C:\Users\munna\AppData\Local\Temp\driver_video_intel_TC50043500C.temp
Is that correct way to install display drivers?
but i could not see new drivers in device manager.
Could you please help me how to delete old drivers and how can i install new drivers?
Hi nic
I have extracted drivers into local and i tried to run setup file.
But i could not able to install drivers and i am getting error like This computer does not have minimum requirements to install the drivers.
Please help on this issue.
NICHOLAS_F_Intel
Just to make sure you're using the right driver; http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2175704&rpn=PSLB0U&modelFilter=L300-ST2501&selCategory=2756709&selFamily=1073768663 Model Content Page
This is the one you're using right? If not, download this one and run the setup file after extraction. Let me know if it works!
-Nic
Hi Nic
Yes the same drivers i tried and i am getting your system does not have minimum requirements to install.
Shiva
NICHOLAS_F_Intel
Okay. There were two L300's listed on Toshiba's* support site, perhaps I gave you the link for the wrong one. Here's the link for the other. It's the Win7* 32-bit display driver, with the version # 8.15.10.1883
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2221250&rpn=PSLB8U&modelFilter=110CS&selCategory=2756709&selFamily=1073768663 Model Content Page
Hello Nic
Finally able to install successfully(version # 8.15.10.1883).Need to wait and see(Have to use for some time) whether this issue resolved permanently or not.
Thanks a lot...
Shiva
Thanks alot nic..Display driver problem resolved permanently....
well i know its a radeon hd 5550 but i use intel e8400 processor. and i m desperate for help. searching web and try to solve this problem nearly 2 weeks now. cant u diagnose. also in task manager so many services stopped working i dont know why. if u want i can take a screenshot the services that are not working. thanks anyway.
Hey Nic,
I also have the same problem with my intel r graphics media accelerator drive for mobile (version 8.15.10.2202) when ever I watch youtube videos and video games. Here is my dxdiag:
ikyuri
ps. I posted a comment just like this a few secs ago but not sure if its posted because it hasen't shown up yet, so sorry for the repeat.
System Information
Time of this report: 2/2/2013, 16:08:41
Machine name: PEIYI-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK Computer Inc.
System Model: K60IJ
BIOS: Default System BIOS
Processor: Pentium(R) Dual-Core CPU T4300 @ 2.10GHz (2 CPUs), ~2.1GHz
Memory: 4096MB RAM
Available OS Memory: 4062MB RAM
Page File: 2921MB used, 5199MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Mobile Intel(R) 4 Series Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_18621043&REV_09
Display Memory: 1695 MB
Dedicated Memory: 64 MB
Shared Memory: 1631 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: HSD160PHW1
Monitor Id: HSD0640
Native Mode: 1366 x 768(p) (59.999Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.2202 (English)
Driver Version: 8.15.10.2202
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 8/25/2010 19:36:02, 6547968 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-6902-11CF-697B-6838A9C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x18621043
Revision ID: 0x0009
Driver Strong Name: oem17.inf:Intel.Mfg.NTamd64:iCNT0:8.15.10.2202:pci\ven_8086&dev_2a42
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Cap...
Hi Nic,
Please look at my DXDiag & suggest me what to do. I just bought this PC & going through the same above issue. Mine goes one more step further. It Freezing the screen & then completely shutting down & rebooting the m/c.
Sanjay.
System Information
Time of this report: 3/6/2013, 18:15:49
Machine name: USER-PC
Operating System: Windows 7 Home Premium 32-bit (6.1, Build 7600) (7600.win7_gdr.130104-1435)
System Manufacturer: Dell Inc.
System Model: OptiPlex 780
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A05
Processor: Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz (2 CPUs), ~2.7GHz
Memory: 6144MB RAM
Available OS Memory: 3036MB RAM
Page File: 1694MB used, 4374MB available
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
Display Devices
Card name: Intel(R) Q45/Q43 Express Chipset (Microsoft Corporation - WDDM 1.1)
Chip type: Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2E12&SUBSYS_04201028&REV_03
Display Memory: 1293 MB
Dedicated Memory: 32 MB
Shared Memory: 1261 MB
Current Mode: 1680 x 1050 (32 bit) (59Hz)
Monitor Model: V223W
Monitor Id: ACR001B
Native Mode: 1680 x 1050(p) (59.954Hz)
Output Type: HD15
Driver Name: igdumd32.dll,igd10umd32.dll
Driver File Version: 8.15.0010.1749 (English)
Driver Version: 8.15.10.1749
DDI Version: 10
Driver Date/Size: 7/13/2009 17:15:31, 3805184 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6D52-11CF-4D75-2A24A3C2C535}
Vendor ID: 0x8086
Device ID: 0x2E12
SubSys ID: 0x04201028
Revision ID: 0x0003
Driver Strong Name: igdlh.inf:Intel.Mfg.NTx86...1:iEGL0:8.15.10.1749:pci\ven_8086&dev_2e12
Rank Of Driver: 00EC2001
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
Hi nic,
I too have a similar problem. I have been using my HP Pavilion dv6 nearly an year, but recently a week back it has started display freezing followed by a system hand after dumping memory in a blue screen. Then i force the system to shutdown by using power button, on restart it shows display driver recovered from a crash. It happens mostly when i watch online videos or using pdf files on browser( google chrome).
Please help me asap. Please see the dxdiag results below.
System Information
Time of this report: 3/7/2013, 23:05:41
Machine name: HP-HP
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
System Manufacturer: Hewlett-Packard
System Model: HP Pavilion dv6 Notebook PC
BIOS: InsydeH2O Version 03.60.48F.1B
Processor: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz (8 CPUs), ~2.2GHz
Memory: 8192MB RAM
Available OS Memory: 8140MB RAM
Page File: 3296MB used, 12980MB available
DxDiag Notes
Sound Tab 2: No problems found.
Display Devices
Card name: Intel(R) HD Graphics Family
Manufacturer: Advanced Micro Devices, Inc.
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_185E103C&REV_09
Display Memory: 4095 MB
Dedicated Memory: 2090 MB
Shared Memory: 2005 MB
Monitor Model: unknown
Monitor Id: CMO15A2
Native Mode: 1366 x 768(p) (59.989Hz)
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx32,igd10umd32,igd10umd32
Driver File Version: 8.15.0010.2476 (English)
Driver Version: 8.882.2.3000
DDI Version: 11
Driver Date/Size: 8/10/2011 02:32:00, 8311808 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4256-11CF-CF77-5438B7C2C535}
Vendor ID: 0x8086
Device ID: 0x0116
SubSys ID: 0x185E103C
Revision ID: 0x0009
Driver Strong Name: oem4.inf:ATI.Mfg.NTamd64.6.1:iSNBM1ML_PROXY:8.882.2.3000:pci\ven_8086&dev_0116&subsys_185e103c
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX Video...
NICHOLAS_F_Intel
@sanjayhbr: First thing, try updating your driver to our latest for your product, and let me know how it goes. Here's a link; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22165&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22165&lang=eng
@Mevin: Try the latest driver we have for your product, let me know how it goes. Here's the link; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521&lang=eng
Thanks everyone,
-Nic
HI Nic,
im running a Dell E6400 with a 32-bit Windows 7 ultimate. i have a similar issue, i think it gets worse when i connect a secondary monitor. it usually does it once at a time, except some time last week it was doing it many times in a row until it self-restarts. hope you can help. this is my dxdiag report:
System Information
Time of this report: 3/10/2013, 17:46:07
Machine name: IKA_E6400
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
System Model: Latitude E6400
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A32
Processor: Intel(R) Core(TM)2 Duo CPU P8400 @ 2.26GHz (2 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 3536MB RAM
Page File: 3281MB used, 3788MB available
DxDiag Notes
Display Tab 2: No problems found.
Display Devices
Card name: Mobile Intel(R) 45 Express Chipset Family (Microsoft Corporation - WDDM 1.1)
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_02331028&REV_07
Display Memory: 1543 MB
Shared Memory: 1511 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor Id: LPL012B
Native Mode: 1280 x 800(p) (59.998Hz)
DDI Version: 10
Driver Date/Size: 7/14/2009 03:15:31, 3805184 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-4D75-3922A7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x02331028
Revision ID: 0x0007
Driver Strong Name: igdlh.inf:Intel.Mfg.NTx86...1:iCNT0:8.15.10.1749:pci\ven_8086&dev_2a42
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,...
Hi!
could you please check mine too?
I thought it's a problem with windows so I formatted my hard disk and re-installed the windows, but apparently that was such a useless call 😕
Here is my dxdiag :
(Thanks in advance )
System Information
Time of this report: 3/13/2013, 09:06:47
Machine name: DELL-PC
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_gdr.130104-1435)
System Model: Inspiron 1545
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A14
Processor: Intel(R) Core(TM)2 Duo CPU P8600 @ 2.40GHz (2 CPUs), ~2.4GHz
Memory: 4096MB RAM
Available OS Memory: 3544MB RAM
Page File: 3852MB used, 3234MB available
DxDiag Notes
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_02AA1028&REV_07
Display Memory: 1548 MB
Shared Memory: 1516 MB
Current Mode: 1366 x 768 (32 bit) (59Hz)
Monitor Id: INL0001
Native Mode: 1366 x 768(p) (59.967Hz)
DDI Version: 10
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-4D75-A022A7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x02AA1028
Revision ID: 0x0007
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Ca...
NICHOLAS_F_Intel
Hi Nic,
I have an HP laptop and don't game at all, but I am having the same sort of problem these others people describe. I am also not very computer literate, so I would greatly appreciate all the help you can give me. Here is my dxdiag report:
Time of this report: 3/13/2013, 18:28:17
Machine name: LAPTOP
Processor: Intel(R) Core(TM)2 Duo CPU T6500 @ 2.10GHz (2 CPUs), ~2.1GHz
Memory: 4096MB RAM
Available OS Memory: 4000MB RAM
Page File: 1668MB used, 6328MB available
DxDiag Notes
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_3627103C&REV_07
Monitor Model: LP156WH1-TLB3
Monitor Id: LGD01D5
Native Mode: 1366 x 768(p) (59.973Hz)
DDI Version: 10
Driver Date/Size: 7/13/2009 21:41:07, 5437952 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-5975-2D16A7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x3627103C
Revision ID: 0x0007
Driver Strong Name: igdlh.inf:Intel.Mfg.NTamd64...1:iCNT0:8.15.10.1749:pci\ven_8086&dev_2a42
can you help me also please? here's the details: Thanks so much!
System Information
Time of this report: 3/15/2013, 00:37:29
Machine name: CHINEYMINKZ-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
System Model: Compaq Presario CQ35 Notebook PC
Memory: 2048MB RAM
Available OS Memory: 1978MB RAM
Page File: 2263MB used, 1694MB available
DxDiag Notes
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_306D103C&REV_07
Display Memory: 797 MB
Shared Memory: 733 MB
Monitor Id: AUO202C
Native Mode: 1366 x 768(p) (60.020Hz)
DDI Version: 10
Driver Date/Size: 7/13/2009 18:41:07, 5437952 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-5975-6710A7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x306D103C
Revision ID: 0x0007
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_St...
