23802 Discussions
Display Scaling option not working
BhavishyaSagar
Recently i have encountered issue of my display not having strech scaling, even though i have enabled it from intel graphics command centre, i remembered once doing the streched display on the same laptop, but now if i want streched resoltion on any game or for normal use, i cant have it, how to pls pls fix this issue..
Laptop Specs :-
mentioned in the files attached...
RandyT_Intel
Hi @BhavishyaSagar,
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • Have you recently updated your Intel Graphics Command Center or any other related drivers? as per checking you are using Intel Graphics Software based on the screenshot you provided.
  • Are you using an external monitor, or is this issue occurring on your laptop's built-in display?( if yes please provide the models)
  • Have you checked the display settings in Windows (or your operating system) to ensure they are configured correctly for stretch scaling?
  • Have you recently changed any hardware components or connections that might affect display settings?
  • Is your laptop connected to any docking stations or adapters that might interfere with display scaling?
  • Have you tried uninstalling and reinstalling the Intel Graphics Software?
  • Have you attempted to roll back to a previous version of the graphics driver where stretch scaling was working?
Note Custom scaling is not available for Built-in Screens of Laptops. The remaining scaling options (Centered, Stretched, and Maintain Aspect Ratio) will be revealed when a screen resolution different than the maximum supported resolution or recommended for the selected display is selected.
Scale Options Are No Longer Available After Updating the Intel®...
Warm regards,
Randy T.
BhavishyaSagar
if you could tell me which version to degrade intel graphics software or command centre or my drivers, that would help the most
BhavishyaSagar
Thank you sir for consideration :-
As for SSU, i cant download the software, because the page is glitched and clicking download button does nothing
i have recently updated intel iris xe drivers to latest version 32.0.1.6881
im using the built-in laptop display
Laptop model - HP Laptop 15s-fy5xxx
Operating system
Windows 11 Home Single Language 64-bit Version: 26100.3775
Microprocessor
12th Gen Intel(R) Core(TM) i5-1235U
System memory
16 GB
Memory slot 1
8GB Samsung 3200MHz
Memory slot 2
8GB Samsung 3200MHz
System board
8A20 20.22
System BIOS
F.24
Video
Graphic device 1
Intel(R) Iris(R) Xe Graphics
Current resolution
1920 x 1080
Refresh rate
60 Hz
Version
32.0.101.6881 (6-4-2025)
Audio
Device 1
Intel® Smart Sound Technology for Bluetooth® Audio
Status
Enabled
Driver
IntcBTAu.sys
Version
10.29.0.10492
Device 2
Realtek High Definition Audio
Status
Enabled
Driver
RTKVHD64.sys
Version
6.0.9721.1
Device 3
Steam Streaming Microphone
Status
Enabled
Driver
SteamStreamingMicrophone.sys
Version
8.33.15.17
Device 4
Intel® Smart Sound Technology for Digital Microphones
Status
Enabled
Driver
IntcDMic.sys
Version
10.29.0.10492
Device 5
Steam Streaming Speakers
Status
Enabled
Driver
SteamStreamingSpeakers.sys
Version
17.56.13.764
No, i have not changed any hardware of software configurations on my laptop
yes i have attempted to roll back my graphics driver to see if the issue is solved, but the issue continues, and i really dont remember the version of the graphics drivers in which i have chnaged my display to STRECHED RESOLUTION. Also, i have tried uninstalling the graphics driver and renstalling but no luck,, really cant download ssu spftware because of the glitch..
As for why i was trying to have a streched resolution, i wanna play microsoft flight simulator 2020, and changing resolution to lower, like 1280 by 720 helped me getting some fps, but switching back to game from menu, or any other app, i can see the samll screena dn black bars aside...
RandyT_Intel
Hi @BhavishyaSagar,
This depends on which software you want to use. If you recently remember which software you were using to stretch the scaling, I assume it is Intel Graphics Command Center. However, since the latest driver contains the latest Intel Graphics software, it is recommended to use this as it is being implemented as a substitute for Intel Graphics Command Center, which has limited support.
Since you do not remember the previous driver you had, we need to isolate the issue by testing the previous or older drivers available in the download center and test the features you recently used. I have sent you an email privately to discuss the next best action. Please check your email.
Warm regards,
Randy T.
RandyT_Intel
Hi @BhavishyaSagar,
Warm regards,
Randy T.
RandyT_Intel
Hi @BhavishyaSagar,
Since I haven't heard back from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you are welcome to submit a new ticket if you need further assistance in the future.
Regarding your primary concern about the inability to achieve stretched resolution, I wanted to provide you with some resources that might help:
Additionally, I suggest trying our Intel Graphics Command Center (IGCC) beta version, which is available for download from the Microsoft Store. This version may offer improvements that resolve the stretching issue you are experiencing. You can download it using the following link: IGCC Beta Download.
Randy T.
