22690 Discussions
DisplayLink and others companies help connect Display via USB
Alx24
New Contributor II
With wide distribution of mobile devices with universal USB-C interface with higher speed capabilities and USB-C DP Alt Mode has appeared a huge number of adapters with USB-C to all existing others graphical interfaces, the number of which does not fit in the mind and the variety of which makes your head spin.
Including those often mentioned here
USB C to HDMI
USB C to DisplayPort
Docking Stations
They allow with extraordinary ease, minimal costs and highly aesthetically replace the missing ports of the computer or tablet and even increase their number.
At the same time, they all have the boundaries of permission specified in the specifications and which are very important.
These adapters are not configurable in any way, which is very simple, good and easy, and accordingly selected.
The fundamental USB interface, which does not lose its importance, has a longer history, highly qualified companies work in this direction, which allows you to completely solve the problem of graphical interfaces.
These interfaces include:
USB A to HDMI
USB A to DisplayPort
USB C to HDMI
USB A to USB C
USB C to USB A
HDMI to DisplayPort
DisplayPort to HDMI
One of these companies, Hardware/Software DisplayLink, is located in Palo Alto, where many of the people of Intel Corp. in Santa Clara have been many times.
https://www.synaptics.com/products/displaylink-graphics/displaylink-products
https://www.displaylink.com/products/hot-products
"Hot Products"
https://www.synaptics.com/products/displaylink-graphics/displaylink-products-list?field_displaylink_category_value=usb_adapters
"USB Adapters"
https://en.wikipedia.org/wiki/DisplayLink
Technology
The DisplayLink network graphics technology is composed of Virtual Graphics Card (VGC) software that is installed on a PC and a Hardware Rendering Engine (HRE) embedded or connected to a display device. The DisplayLink VGC software is based on a proprietary adaptive graphics technology. The VGC software runs on a Windows, macOS, or Linux host PC and takes information from the graphics adapter and compresses the changes to the display from the last update and sends it over any standard network including USB, Wireless USB, Ethernet, and Wi-Fi. After receiving the data, the HRE then transforms it back into pixels to be displayed on the monitor. While the basic network graphics technology can be used on a variety of network interfaces (Ethernet, and Wi-Fi), DisplayLink has to date only designed products around USB 2.0, USB 3.0, and Wireless USB connectivity.[17]
DL-41xx
The DL-41xx series came out in 2013. It is a USB 3.0 to LVDS device, supporting DL3 compression and HDCP 2.0 encryption.[24] It is designed to be embedded into monitors to enable USB as a video input on displays. It is described as a low power device, which enables it to be powered from the USB bus without the need for an external power supply. Power and video data can be delivered over a single cable.[25]
The IC has been integrated into a number of portable USB displays from AOC, ASUS and Taeseok.[26]
DL-5xxx
The DL-5xxx series was the first USB 3.0 graphics chipset to support 4K UHD resolutions. The chipset was launched in 2014 at Interop.[27]
DL-6xxx
The DL-6xxx series was announced at CES 2016.[14] This chip supports dual 4Kp60 displays over a USB-C or USB Standard A connector.
A key feature of DisplayLink technology is video compression, allowing the use of USB 2.0 and USB 3.0
https://www.synaptics.com/products/displaylink-graphics/usb-c
​​​​​​"What is USB-C?"
https://www.ldlc.com/en/product/PB00423550.html
"Understanding DisplayLink, multiple displays, and M1 Macs"
https://www.reddit.com/r/PixelBook/comments/9cmdme/displaylink_dock_vs_usb_c_to_hdmi/
"Displaylink dock vs USB C to HDMI"
Products
https://www.amazon.com/usb-hdmi-displaylink/s?k=usb+to+hdmi+displaylink
https://www.amazon.com/usb-displayport-displaylink/s?k=usb+to+displayport+displaylink
https://StarTech.com
https://www.startech.com/en-us/audio-video-products/display-and-video-adapters
"Display and Video Adapters"
https://www.startech.com/en-us/audio-video-products/usb32hd4k
"USB 3.0 to HDMI Adapter - 4K 30Hz Ultra HD - DisplayLink Certified - USB Type-A to HDMI Display Adapter Converter for Monitor - External Video & Graphics Card - Mac & Windows"
https://www.startech.com/en-us/audio-video-products/usb32dpes2
"USB 3.0 to DisplayPort Adapter - 4K 30Hz"
https://www.startech.com/en-us/audio-video-products/usb32dp4k
"USB 3.0 to DisplayPort Adapter - DisplayLink Certified - 4K 30Hz"
Dual DisplayPort and Dual HDMI
https://www.startech.com/en-us/audio-video-products/usb32dp24k60
"USB 3.0 to Dual DisplayPort Adapter - 4K 60Hz"
USB A can be connected via USB C to USB A connector
https://i-tec.pro/en/produkt/u3dual4khdmi-2/
i-tec USB 3.0 / USB-C Dual 4K HDMI Video Adapter
Another group of companies uses other chips and drivers
https://www.insigniaproducts.com/pdp/NS-PCA3H/6418342
"Insignia - USB to HDMI Adapter"
These adapters do not have any settings but their performance may vary depending on the type of connection
"4K resolution: Provides high-quality, 4K resolution at 30 Hz when using USB 3.0.
Backwards compatible: Backwards compatible with USB 2.0 (max resolution 2048 x 1152) to work with older computers."
Kennesaw, Georgia
https://en.j5create.com/
"j5create is a computer peripheral company dedicated to providing high-quality products."
https://en.j5create.com/pages/about-us
https://en.j5create.com/blogs/press-room
https://en.j5create.com/pages/contact-us
"LIVE CHAT HOURS"
https://en.j5create.com/products/jua354
"USB™ 3.0 to 4K HDMI™ Display Adapter"
https://www.amazon.com/s?k=j5create+usb+to+hdmi+adapter
https://www.amazon.com/s?k=j5create+usb+to+displayport+adapter
WWW Link
https://en.j5create.com/pages/drivers
gives s list of all products
https://www.facebook.com/j5create/
https://www.youtube.com/c/j5createtoday
https://www.instagram.com/j5create/
https://www.instagram.com/p/CTMxItSsMqZ/
"Keeping you connected to all of your favorite legacy USB™ devices."
https://twitter.com/j5create
Alx24.
