22737 Discussions
Does G41 support OpenGL2.1 in Win7 x86?
I cannot use any opengl 2.1 program in windows 7 x86
It seems that the driver does not have the required components to run opengl 2.1
Is there any method to run those program?
Driver Version: 15.16.5.2021
Apparently, from the Specification update and the link below, it appears that it has only been validated on Opengl Version 2.0.
http://www.intel.com/Assets/PDF/specupdate/319971.pdf Link 1
http://www.intel.com/support/graphics/sb/CS-030053.htm Link 2
Hope you can get more information from someone else.
All the best,
Kind Regards,
Aryan.
It should be if the opengl version is greater than 1.1, it will not run.
It is checked by GPU Caps Viewer and show
How can I fix it?
Why dont you check on this community, may be someone can help you overthere?
http://software.intel.com/en-us/blogs/
Hopefully someone can help you on this one here.
Note: I have removed the Re: at the beginning of the your question, so that someone can check it.
All the best,
Kind Regards,
Aryan.
