22698 Discussions
Does Intel Arc Graphics do well with LCD monitors?
PasteuU
Hello. I have an Intel ARC A770 8GB (Drivers 31.0.101.4091) that runs an i5-12400 with a Lenovo S22e-19 LCD display in video output.
My problem is that the dedicated card does not faithfully reproduce the black tones when its "really dark" and, consequently, the same contrast that is characteristic of displays with LCD technology that, by the way, are present in my experience using the UHD 730 integrated into the CPU.
I couldn't find a configuration tab involving color and screen in ArcControl. So I'm here requesting some help to help me understand the problem.
Hugo_Intel
Hello PasteuU
Thank you for posting on the Intel Communities. I am sorry to hear that you are experiencing issues adjusting the color on your Intel® Arc™ A770 Graphics.
Please check the following article which explains why the option to configure color on Intel® Arc™ is not yet available as well as a workaround that you could use at the moment to adjust these settings:
How to Change the Color Depth in the Intel Graphics Command Center when using Intel® Arc™ Limited Edition Graphics Cards
Hugo O.
Hugo_Intel
Hello PasteuU
Hugo O.
Hugo_Intel
Hello PasteuU
I hope you are doing fine.
Hugo O.
Hugo_Intel
Hello PasteuU
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
PasteuU
Hello again. I'm sorry for not responding.
Your answer helped me and my problem, in particular, was resolved by changing the Hz of my monitor, as well as a few visits to the device manager.
Finally, it's really good that they added color settings to Arc Control. I hope it gets even better 🙂
