Hi, I'm upgrading my Lenovo Ideapad 1i, and it uses the Celeron N4020, which has the Intel UHD Graphics 600. since i'm replacing the monitor for an 120hz ips panel, i want to know if the Graphics would be supported, or if i should stick to 60hz. that's all
It depends on the desired resolution. The Intel UHD Graphics 600 supports a maximum pixel clock of 300 MHz.
According to Lenovo's official specifications, the IdeaPad 1i has an HDMI port (version 1.4b) as its only video output.
1920 x 1080 @ 120 Hz RGB 8-bit (CTA-861) = 297 MHz pixel clock
In my opinion, this should work. Resolutions above Full HD are not possible at 120 Hz.
