22662 Discussions
Does the Intel UHD graphics 600 Support 120hz?
idjiota
Hi, I'm upgrading my Lenovo Ideapad 1i, and it uses the Celeron N4020, which has the Intel UHD Graphics 600. since i'm replacing the monitor for an 120hz ips panel, i want to know if the Graphics would be supported, or if i should stick to 60hz. that's all
MUC
Honored Contributor I
It depends on the desired resolution. The Intel UHD Graphics 600 supports a maximum pixel clock of 300 MHz.
According to Lenovo's official specifications, the IdeaPad 1i has an HDMI port (version 1.4b) as its only video output.
1920 x 1080 @ 120 Hz RGB 8-bit (CTA-861) = 297 MHz pixel clock
In my opinion, this should work. Resolutions above Full HD are not possible at 120 Hz.
