Is anyone else having issues downloading the 64-bit latest drivers for the Intel HD4000 Graphics (3rd Gen Core)?
I need the 64-bit drivers for Windows 7, but neither the EXE nor the ZIP seem to work, the links seem broken:
Is anyone else having these issues? Is there an alternative place where I can download these?
Thanks for your help.
- 標籤:
- Drivers
連結已複製
@GGB,, What browser are you using? I have verified the downloads work with IE 8, 9 , & 10. Here are direct links.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22375 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22375 64 exe
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22376 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22376 64 zip
downloadmirror.intel.com/22373/a08/win32_152812.exe - Windows 7/8 - 32bit
downloadmirror.intel.com/22375/a08/win64_152812.exe - Windows 7/8 - 64bit
case-sensitive - on sites INTEL :F
I am experiencing the same issue, also using Google Chrome.
Edit: Got it to work. I couldn't even get the driver page to load in internet explorer; it was loading in Chrome but the download link wouldn't work. So, I copied and pasted the download link from Chrome and put it into IE and it worked.
The links in this thread are almost a year old, so they don't work anymore.
Try http://intel.ly/1kkevWP http://intel.ly/1kkevWP to manually download drivers for Intel® HD Graphics 4000.
Or use the automatic update tool at http://www.intel.com/p/en_US/support/detect?iid=dc_iduu Intel® Driver Update Utility.
Mark
I just did it using "Driver Update Utility" and it downloads... my problem is: when i run the instalation, it shows me the message that the operating system is not compatible....
i am using windows 7, and supposedly it has to be detected by using the driver update utility, can some one help me what can i do?
Hello Eyen,
Please try with the manual driver installation. Here you have the steps:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
If you are still having problems, please post here the driver you are trying to install (link) and your computer specifications.
Kevin M
Hello, I seem to be unable to update my Intel(R) HD Graphics 4000 driver. I have an HP Pavilion m7 Notebook PC which is running a Windows 7 64-bit operating system. I have tried both the automatic utility and the manual download processes, but neither seem to do the trick. The utility says "The file that you are trying to download has either been moved, renamed or archived." It then redirects me to a manual download link, which after downloading, says either that the operating system is not supported or that the driver is not validated for this computer. I have tried using chrome and IE. The version I am trying to download is 8.15.10.2712
Please try this driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3720&DwnldID=23884 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3720&DwnldID=23884
If you have problems installing it try the steps mentioned here:
Please can any one provide a working link so I can download any of the working versions for Arma 3? It seems that only old drivers works properly
As Beelzebassie 29/11/2013 16:26 said, only 2817 2867 2875 2932 version driver works. All of the pages I visit are broken. I have a Windows 7 32 bits Intel HD 4000 laptop
Those drivers are gone from intel pages and even intel is having problems to find them or to understand that we need old drivers no the updated ones, they are doing something bad with new drivers 😞
Thnak you in advace
We do not have the driver available anymore at Intel® Website but you can search for it on the web.
As an example, here you have this version:
http://www.redway3d.com/drivers/Win_eight64_Intel(r)%20Graphics%20Media%20Accelerator%20Driver%2015.28.12.64.2932.php http://www.redway3d.com/drivers/Win_eight64_Intel(r)%20Graphics%20Media%20Accelerator%20Driver%2015.28.12.64.2932.php
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Kevin M
Thank you very much
I found this from Dell, I didnt notice that the hole number was 9.17.10.2932, so sorry for that, my mistake
http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=6C95R Intel HD, HD 2000/2500/3000/4000 Windows7/8 32-bit Driver Driver Details | Dell US
http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=GVR6H Intel HD, HD 2000/2500/3000/4000 Windows7/8 64-bit Driver Driver Details | Dell US
