23118 Discussions
Drive isn't installing
Easin
The GPU driver isn’t installing. I’ve tried several versions, but the result is always the same. When I try to install the driver, my PC restarts as soon as the file starts extracting. I also tried manually extracting the GPU driver files to a different folder, but it’s the same , the PC restarts during extraction.
This only happens with GPU driver files; I can extract any other files without issues. I’ve also tried using DDU for cleanup and even installed a fresh copy of Windows, but the problem still persists. I’ve checked the RAM and SSD both are fine. My PC runs perfectly without the GPU installed.
Easin
My GPU: Sparkle Intel Arc A770 Titan
