I downloaded the Intel Driver Update Utility 2.8.1 and installed it.
When I try to start it I get the following error:
I want to update my driver for HD Graphics 3000, because it is not working after installing the Creators Update on W10.
I rolled the system back to the prior version, and now I want to try updating the driver.
The driver version I downloaded ( filename win64_154001.exe ) won't install, it says that the software does not support the hardware...
Ehm...., I do have the HD Grapics 3000. (Machine is an ASUS laptop N73 series, an oldie but still working fine)
(it is in Dutch, but you'll understand)
So any ideas?
- Tags:
- Drivers
Hello Jagio,
Thank you for contacting Intel Communities.
I will be more than happy to help you with the Intel® Driver Update Utility issue. Please try the following:
- Use the Windows Search (next to the start button) and look for "Services".
- Locate the Intel(R) Driver and Support Assistant > Right click > Properties > Startup type > Automatic > click Apply.
- Locate the Intel(R) System Usage Report Service SystemUsageReportSvc_QUEENCREEK > Right click > Properties > Startup type > Automatic > click Apply.
- Restart the computer.
https://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products.
https://www.intel.com/content/www/us/en/support/processors/000006105.html Intel® Processor Support for Microsoft Windows® 10
As for the graphics driver for Windows® 10, I have sent you a private message.
I hope this information helps.
Juan V.
![](/skins/images/7400F44FEAF4312DA521E61720D9D5D9/responsive_peak/images/icon_anonymous_message.png)
Topic Options
