23783 Discussions
Driver help
reqwezu
Hello, I have encountered a big problem.
I need to find a driver for the integrated graphics card Intel HD Graphics 3000, I found a few but they are for other versions of the driver and it shows that the system does not meet the requirements something like this,
the exact version of my integrated graphics card is: 9.17.10.4459
Please help quickly
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[If you find any Intel driver you might need, download and save it now.]
n_scott_pearson
You have a 2nd gen. processor and its graphics engine has never been supported with Windows 10 or 11. The only driver available is the compatibility driver provided inbox by Microsoft. I presume that you are here looking for an upgrade for this driver because its support is poor and its performance abysmal. Well, I'm sorry, but there simply are no other drivers available.
Reality bites, time to upgrade your hardware.
