22931 Discussions
Edge et page assitant pilote
Aégon
Bonjour,
La page internet de l’assistant pilote ne fonctionne plus sur edge mais sur chrome oui depuis vendredi environs.
C’est normal ?
Merci
RajashekarK_Intel
Thank you for posting your question. We only provide support in English. I have translated your question.
The web page of the driver assistant no longer works on Edge but on Chrome Yes since about Friday.
 Is this normal?
Does this reflect your question correctly and please let us know which web page you are trying to access.
Rajashekar
Aégon
DeividA_Intel
Hello Aégon,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with the Intel® Driver & Support Assistant (Intel® DSA).
1. Does the issue persists?
2. Are you getting any errors? If so, can you take a picture?
3. What is the operating system installed as well as the version and build?
4. Do you have an antivirus enabled?
5. Are you using a laptop or desktop computer?
Deivid A.
DeividA_Intel
Hello Aégon,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
Aégon
1. Does the problem persist?
Yes
2. Are you getting errors? If yes, can you take a photo?
I get the error: Sorry, there was a problem trying to scan.
win 11 // 22621.1702
4. Do you have antivirus enabled?
yes bitdefender
desk
DeividA_Intel
Hello Aégon,
Thanks for the confirmation. In order to continue, please try the following:
1. Clear the browser cache and close the browser.
2. Try disabling your Ad Blocking extensions and privacy-related extension on the Intel® Driver & Support Assistant (Intel® DSA) webpage.
3. Ensure both the Intel® DSA Service and Intel® DSA Updater service show the status of Running:
  • In Windows* Search, type Services, and scroll to find Intel® Driver & Support Assistant.
  • Confirm the Status shows Running; if it isn't running, then start the service if necessary by right-clicking and choosing Start.
  • If the Status shows Running, restart both services by right-clicking and choosing Restart.
4. Uninstall the existing Intel® Driver & Support Assistant (Intel® DSA) tool in the system using the Uninstaller tool.
Deivid A.
Aégon
Hello, I tried everything you told me but it still does not work on Microsoft edge, so I have to go to chrome to use it cordially,
DeividA_Intel
Hello aégon,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello Aégon,
In order to continue with the investigation, please provide the version of the Edge browser.
Deivid A.
Aégon
david2212
It's possible that there have been recent changes or compatibility issues between the specific webpage and the Edge browser. Try clearing the browser cache and updating Edge to see if that resolves the problem.
DeividA_Intel
Hello Aégon,
Thanks for the confirmation. I will continue with the investigation and get back to you as soon as possible.
Deivid A.
DeividA_Intel
Hello Aégon,
Thanks for your patience. Based on the tests performed, the Intel® Driver & Support Assistant (Intel® DSA) should work with the latest version of Microsoft Edge.
Please try to rescan using the latest version of Microsoft Edge (113.0.1774.57).
Let me know if the issue persists.
Deivid A.
Aégon
Good morning,
I have the latest version of edge is yet I still have the same problem. Maybe an extension that prevents the scan?
Aégon
I disabled the extensions is still the same, maybe options in the edge settings that prevent the scan?
DeividA_Intel
Hello Aégon,
Thanks for the confirmation, I would like to keep investigating this behavior. To proceed I will need the following:
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. The logs from the Intel® Driver & Support Assistant (Intel® DSA):
Deivid A.
DeividA_Intel
Hello Aégon,
I reviewed your post, please let me know if the issue was resolved, if not, do not hesitate, just reply back with the following information:
Deivid A.
DeividA_Intel
Hello Aégon,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
Aégon
Good morning,
No it still doesn't work with microsoft edge.
Cordially
