22896 Discussions
Error installing intel-i915-dkms on 6.5.0-41-generic
FCM
DKMS make.log for intel-i915-dkms-0.5949.220707.2.1013 for kernel 6.5.0-41-generic (x86_64)
Fri 12 Jul 15:53:00 EEST 2024
Generating local configuration database from kernel ...Kernel version parse failed!
make: *** [Makefile:183: olddefconfig] Error 1
expr: non-integer argument
set -e; mkdir -p /var/lib/dkms/intel-i915-dkms/0.5949.220707.2.1013/build/backport-include/linux/; {         echo '#define UBUNTU_BACKPORT_MAJOR 41'; echo '#define UBUNTU_BACKPORT_MINOR 41~22'; echo '#define UBUNTU_BACKPORT_RELEASE_VERSION(a,b) (((a) << 16) + ((b) << 8))'; echo '#define UBUNTU_BACKPORT_RELEASE_COD>Generating local configuration database from kernel ...Kernel version parse failed!
make[1]: *** [Makefile:183: modules] Error 1
make: *** [Makefile:31: default] Error 2
Hello, trying to install ARC310 driver on Ubuntu Server 22.04 with 6.5 kernel and I get this error.
I am using
apt install -y intel-i915-dkms
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
intel-i915-dkms is already the newest version (0.5949.220707.2.5.17.0.1013+i5-1).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up intel-i915-dkms (0.5949.220707.2.5.17.0.1013+i5-1) ...
Removing old intel-i915-dkms-0.5949.220707.2.1013 DKMS files...
Deleting module intel-i915-dkms-0.5949.220707.2.1013 completely from the DKMS tree.
Loading new intel-i915-dkms-0.5949.220707.2.1013 DKMS files...
Building for 6.5.0-41-generic
Building initial module for 6.5.0-41-generic
Error! Bad return status for module build on kernel: 6.5.0-41-generic (x86_64)
Consult /var/lib/dkms/intel-i915-dkms/0.5949.220707.2.1013/build/make.log for more information.
dpkg: error processing package intel-i915-dkms (--configure):
 installed intel-i915-dkms package post-installation script subprocess returned error exit status 10
Errors were encountered while processing:
 intel-i915-dkms
Any suggestions, please?
FCM
I have the same issue with 5.15 kernel, the one actually recommended by the install guide.
Any solutions to try, please?
FCM
The guide at https://dgpu-docs.intel.com/driver/client/overview.html is not working, I can't build the module locally for either kernel 5.15 or 6.5 hwe.
Can some Intel Linux chad look at this please and give some pointers?
Should I post in a different area of the forums?
jiminli
Root cause:
linux-hwe-6.5-headers-6.5.0-18/include/drm/display/drm_dp_mst_helper.h:835:int drm_dp_calc_pbn_mode(int clock, int bpp, bool dsc);
linux-hwe-6.5-headers-6.5.0-41/include/drm/display/drm_dp_mst_helper.h:835:int drm_dp_calc_pbn_mode(int clock, int bpp);
drm_dp_calc_pbn_mode() prototype has changed in 6.5.0-41, leading to mismatch with i915-dkms.
Possible solution:
After installing Ubuntu 22.04 (say 22.04.4), don't apt upgrade, especially don't install & upgrade linux-image-generic-hwe-22.04.
To turn off Ubuntu Unattended-Upgrades:
sudo systemctl disable --now unattended-upgrades
sudo nano /etc/apt/apt.conf.d/20auto-upgrades, setting Unattended-Upgrade as "0".
FCM
But this happens when I revert to the mainline non hwe kernel 5.15.
See attached crash log for details.
FCM
Beside the crash report in the previous post, I have attached a report generated by Intel SSU.
Please let me know how to proceed.
Both kernel version recommended in Intel guides (mainline 5.15 and hwe 6.5) do not work out of the box.
I am running Ubuntu 22.04.4 Server, everything should install.
PS: I have edited some S/N for privacy.
@jiminli
jiminli
Please list your command sequences after the installation of ubuntu 22.04.
and the output of `uname -a`
FCM
I have added the answers in the text file and attached it since this forum is complaining about using some restricted characters.
See attached commands.txt
jiminli
As far as I know, the current intel-i915-dkms cannot work with Ubuntu 6.5.0-41-generic, so don't do your typical "apt upgrade" after an install.
jiminli
What I'm using is intel-i915-dkms/1.24.2.17.240301.20 + ubuntu Desktop 22.04.4, which is a working pair.
Your intel-i915-dkms (intel-i915-dkms-0.5949.220707.2.1013) seems too out-of-date.
FCM
How can I get an updated version of intel-i915-dkms?
Is there a specific PPA I should add?
I am running Ubuntu Server 22.04.4
jiminli
Which user guide are you following?
You should do some steps similar below :
```sh
wget -qO - https://repositories.intel.com/gpu/intel-graphics.key | sudo gpg --dearmor --output /usr/share/keyrings/intel-graphics.gpg
echo "deb [arch=amd64,i386 signed-by=/usr/share/keyrings/intel-graphics.gpg] https://repositories.intel.com/gpu/ubuntu jammy client" | sudo tee /etc/apt/sources.list.d/intel-gpu-jammy.list
sudo apt update
FCM
I have the same issue with the 5.15 kernel.
Which exact kernel version should I use?
Thanks!
