23459 Discussions
Error log (when trying to install driver 31.0.101.5590)? Can't install new graphics drivers! Help!
Tempz
This download installs Intel® Graphics Driver 31.0.101.5590 (WHQL Certified) for Intel® Arc™ A-Series Graphics, Intel® Iris® Xe Graphics, and Intel® Core™ Ultra Processors with Intel® Arc™ Graphics.
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Older drivers (on computer) 31.0.101.5186, Intel's 11th Gen CPU (integrated GPU).
From error log (when trying to install driver 31.0.101.5590):
[4/18]
Operation: Delete "C:\Program Files\Intel\Media Resource\igd11dxva32.dll" file ||
2024/06/23 14:17:16.002|INFO|All operation conditions are satisfied. Running operation. ||
2024/06/23 14:17:16.002|ERROR|Problem with deleting the C:\Program Files\Intel\Media Resource\igd11dxva32.dll file. Reason: Access to the path 'C:\Program Files\Intel\Media Resource\igd11dxva32.dll' is denied.. ||
2024/06/23 14:17:16.002|ERROR|Aborting operation. (last operation fatal failed) ||
Full error log:
https://pastebin.com/q6VASyBu
Mike_Intel
Hello Tempz,
Thank you for patiently waiting for our update.
Kindly try the following steps and check if this will fix the issue:
1. Download the driver version 32.0.101.5762.
2. After the download is complete, create a new folder on your computer to store the driver.
3. Move the downloaded graphics driver file into this new folder.
4. Right-click on the file, choose 'Show more options', and then select '7-zip'. (You may also use a third-party application to zip the file, such as 7-Zip. with a file name: Download 7-Zip 24.07 (2024-06-19) for Windows x64 (64-bit):)
5. Click on 'Extract Here', wait for the extraction process to complete, and then close the window.
6. Open the Device Manager, locate the UHD Graphics 750, and right-click on it.
7. Choose 'Properties', followed by 'Update Driver'.
8. Select 'Browse my computer for drivers' and navigate to the folder where you placed the driver.
9. Confirm your selection, click 'Next', and allow the installation to proceed to completion.
For reference, I would like to share this community link https://community.intel.com/t5/Graphics/Acer-Bifrost-A770-Card-Installation-Failure/m-p/1598957#M131082
There is a video guide in that link that you can follow too.
The steps in this link are applicable to integrated graphics cards as well. Please let us know if this resolves the issue. If the problem persists, we will investigate further.
Michael L.
Mike_Intel
Hello Tempz,
For us to further check this, please help provide the following details:
  1. What is the complete model of your processor?
  2. Where did you download this driver? Can you share the link?
  3. What is your Operating system?
Michael L.
Tempz
What is the complete model of your processor? Intel Core i7-11700
What is your Operating system? Windows 10 Home (22H2)
Mike_Intel
Hello Tempz,
Thank you for the quick response.
The latest driver for your Graphics is 31.0.101.5592.
You can download and install it manually from this link:
Michael L.
Tempz
Still I can't update a new drivers (see IntelGFX.log)!
Mike_Intel
Hello Tempz,
Did you try to run it as Administrator?
What is the error that you encounter? can you share a screenshot of the error?
Michael L.
Tempz
Did you try to run it as Administrator? Yes
What is the error that you encounter? Look at IntelGFX.log and/or my first post.
can you share a screenshot of the error? See attachment.
Mike_Intel
Hello Tempz,
I am sorry, can you help translate the error code in the screenshot?
We should have a recommendation for this error if you can help in translating it.
Michael L.
Tempz
"x Something went wrong.
The installer failed to install this driver properly. Restart the system
and try again. If the problem persists, contact Intel Customer Support for further assistance.
Installation exit code: 1
Error log
[Close] [Restart Recommended]"
And yes, I restarted several times my computer without any help.
Mike_Intel
Hello Tempz,
I have 2 links right here that you can follow. Both recommendations is for the error that you encounter.
https://www.intel.com/content/www/us/en/support/articles/000087784/graphics.html
https://www.intel.com/content/www/us/en/support/articles/000087660/graphics.html
Michael L.
Mike_Intel
Hello Tempz,
Michael L.
Tempz
I found posts on the forum that after installing Microsoft's generic drivers, users were still unable to install Intel graphics drivers.
Mike_Intel
Hello Tempz,
Just to clarify, did you try to follow the steps from the 2 links that I shared on my previous post?
Michael L.
Tempz
I didn't try to install the microsoft graphics driver because some users have had problems with the situation in question. At the moment, the computer is working, and I don't need the latest Intel graphics drivers for e.g. gaming.
Mike_Intel
Hello Tempz,
The latest that we have right now is 31.0.101.5594.
Would you like to try this one? If you would like to try this, just don't forget to right click and run it as Administrator. Here is the link.
Michael L.
Tempz
I tried to update Intel Graphics Drivers 32.0.101.5762 without any success.
Mike_Intel
Hello Tempz,
Let me ask some questions base on your reply.
  1. Are you getting any error message installing 32.0.101.5762?
  2. Where did you download the version 32.0.101.5762
  3. Have you tried to check our last post, we recommended to try the version 31.0.101.5594. Have you also tried this one?
Michael L.
Tempz
Are you getting any error message installing 32.0.101.5762? Installation exit code: 1
Where did you download the version 32.0.101.5762? https://www.intel.com/content/www/us/en/download/785597/826612/intel-arc-iris-xe-graphics-windows.html
Have you tried to check our last post, we recommended to try the version 31.0.101.5594. Have you also tried this one? Yes.
Mike_Intel
Hello Tempz,
Please help generate the SSU logs of your system. Kindly open the link below for the instructions:
Michael L.
Tempz
Mike_Intel
Hello Tempz,
We will do further research on this matter and post the response on this thread once it is available.
Have a fantastic day, and thank you very much for your patience and understanding!
Michael L.
