23089 Discussions
Error message that result in my computer to freez.
Following error message appears in Computer Management, Application log:
AID Option ROM Version: 7.5.0.1017
Driver Version: 7.5.0.1017
RAID Plug-In Version: 7.5.0.1017
Language Resource Version of the RAID Plug-In: File not found
Create Volume Wizard Version: 7.5.0.1017
Language Resource Version of the Create Volume Wizard: File not found
Create Volume from Existing Hard Drive Wizard Version: 7.5.0.1017
Language Resource Version of the Create Volume from Existing Hard Drive Wizard: File not found
Modify Volume Wizard Version: 7.5.0.1017
Language Resource Version of the Modify Volume Wizard: File not found
Delete Volume Wizard Version: 7.5.0.1017
Language Resource Version of the Delete Volume Wizard: File not found
ISDI Library Version: 7.5.0.1017
Event Monitor User Notification Tool Version: 7.5.0.1017
Language Resource Version of the Event Monitor User Notification Tool: File not found
Event Monitor Version: 7.5.0.1017
Array_0000
Status: No active migration(s)
Hard Drive Write Cache Enabled: Yes
Free Space: 0 GB
Number of Hard Drives: 2
Hard Drive Member 1: SAMSUNG HD502HJ
Hard Drive Member 2: SAMSUNG HD501LJ
Number of Volumes: 1
Volume Member 1: Volume0
Volume0
Status: Normal
System Volume: Yes
Volume Write-Back Cache Enabled: No
RAID Level: RAID 1 (mirroring)
Physical Sector Size: 512 Bytes
Logical Sector Size: 512 Bytes
Parent Array: Array_0000
Hard Drive 0
Usage: Array member
Status: Normal
Device Port: 0
Device Port Location: Internal
Current Serial ATA Transfer Mode: Generation 2
Model: SAMSUNG HD502HJ
Serial Number: S20BJ90S810974
Firmware: 1AJ100E4
Native Command Queuing Support: Yes
Hard Drive 1
Usage: Array member
Status: Normal
Device Port: 1
Model: SAMSUNG HD501LJ
Serial Number: S0MUJ1CQ988014
Firmware: CR100-13
Unused Port 0
Device Port: 2
Unused Port 1
Device Port: 4
Unused Port 2
Device Port: 5
CD/DVD Drive 0
Device Port: 3
Current Serial ATA Transfer Mode: Generation 1
Model: TSSTcorp CDDVDW SH-S203D
Serial Number: Data not reported
Firmware: SB00
How can I solve this problem.
Thank you in advance.
Kind regards
Dag N
