22824 Discussões
Failed To Install Graphics Card
TheGaymer
Principiante
2.020 Visualizações
hi, i have i7 9700k and ive been trying to download intel uhd 630 but when i install it, i get an error saying that my OS isnt supported I have Windows 10 64 bit
8 Respostas
AlHill
Superusuário
2.014 Visualizações
What version of W10?
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
TheGaymer
Principiante
2.009 Visualizações
Version 1909 (OS Build 18363. 1198)
if I attached the file, everyone would see it...
AlHill
Superusuário
2.002 Visualizações
Yes, that is true.  But, there is nothing to personally identify you in the file.
TheGaymer
Principiante
1.999 Visualizações
there are network info, and serial numbers... still would rather ti not publish it publicly
AlHill
Superusuário
1.995 Visualizações
Sorry, but that is the way it is.  Perhaps one of the intel support engineers can help you.
Also, if you look in the forum, there are thousands of users have have posted the ssu report, without issue.
TheGaymer
Principiante
1.993 Visualizações
alright here it is
TheGaymer
Principiante
1.979 Visualizações
AlHill
Superusuário
1.971 Visualizações
Your windows 10 could  be updated.
Also, you have nvidia graphics.  When you insert a graphics card, it will likely disable the Intel processor graphics.  You will need to check the bios to see if you can have both active at the same time.  Don't know how to check the bios?  Contact Asustek and ask them for help with their bios.
Responder
