22649 Discusiones
Failed to download Intel Endurance Gaming Mode
LT7879
Nuevo Colaborador I
9.227 Vistas
Hi all,
When I opened Intel Driver & Support Assistant, there is an update for InteL Endurance Gaming Mode version 1.5.651.0.  But when I tried to download it, it always failed with the message download failed unexpectedly. I attached the screenshot. Can anyone advise how to fix it?
Thank you
0 kudos
1 Solución
Monster
Novato
8.274 Vistas
Don't worry guys i'm here for solve your problem 😏 I made some attempts to solve it and finally I did it, just open a cmd as administrator (right click on cmd and click run as administrator) and open the installer from the cmd just copy the directory where is the installation file located and run It .
Thank me later 💪
Ver la solución en mensaje original publicado
11 Respuestas
RobbieR_Intel
Moderador
8.878 Vistas
Hello LT7879,
Thank you for reaching out. To resolve the "download failed unexpectedly" issue with Intel(R) Driver & Support Assistant, you can try the following:
  1. Open Intel(R) Driver Support Assistant > Settings.
  2. Under "Folder Location," click Change Location and select a new folder for downloads.
  3. Ensure no adblockers or browser extensions are blocking downloads.
  • Run Intel(R) Driver Support Assistant and run it as Administrator
  • Temporarily Disable Antivirus/Firewall, as these can sometimes block downloads.
For more information, kindly refer to “Unexpected Download Error” or “Multiple Download... (intel.com)
We look forward for your response.
Robbie R.
LT7879
Nuevo Colaborador I
8.871 Vistas
Dear Robbie,
I have tried the proposed solution in the article you mentioned above, but it still gave the same error message. Do you have a direct link I can use to download it?
Thank you
LT7879
Monster
Novato
8.594 Vistas
Me too same problem adblock and chance location download doesn't help msi claw my pc all driver download good
Monster
Novato
8.588 Vistas
Intel® Endurance Gaming Mode
That for u bro 💪 i have solved
LT7879
Nuevo Colaborador I
8.431 Vistas
Hi Monster,
thank you for the download link, I have tried to install it, but it gave me an error message : the setup wizard ended prematurely, can you advise on how to install it? did you uninstall the older one first?
ZackMsi24
Principiante
8.419 Vistas
same i also facing the same issues. just when i thought require to uninstall the previous version of endurance gaming.
now i dont have the driver for endurance gaming and the latest version failed and ended prematurely.
Monster
Novato
8.275 Vistas
Thank me later 💪
LT7879
Nuevo Colaborador I
8.227 Vistas
Hi @Monster
It works 👍
Thank you so much.
xenoside
Principiante
8.064 Vistas
setup requires administrator privileges during installation.
However, there is something wrong with some process that runs without administrator privileges and simply doesn't recognize that the assistant is installed.
If I run cmd as administrator and run setup, it is recognized properly, but this is not normal.
setup needs to be improved.
thank you.
blondeboyzz
Principiante
6.266 Vistas
Yeah, nooo...this does not work.  I have tried running cmd as admin and it doesn't work.  I tried running the intel assistant as admin...doesn't work.  I tried changing the file location...it doesn't work.  Intel needs to fix this problem!
ChamCham48
Principiante
6.057 Vistas
This used to work by running through administrator CMD prompt but now it does not.  Needs to be fixed for Windows 11.  How did this even pass QA?
Responder
