22773 Discussions
Fallas en los juegos con la Arc a770 de 16gb
TheRitrax
Luego de instalar mi Arc a770 y empecé a jugar vi que a vecespasa que en los juegos como Red Dead Redemption 2 y Fortnite vi la mitad de la pantalla un linea blanco y partes negras (no le movi a nada a la gpu ni al overclock), luego de ver eso es como si todo se viera negro y no reconoce mi mouse y mi teclado
Jean_Intel
Hello TheRitrax,
It is important to mention that our support is only provided in English. To better assist you, we use a translation tool; hence, the translation may not be completely accurate.
We would like to gather the following information to better assist you:
  • Is this issue present since day one?
  • Is this the original Graphics card installed on your system?
  • Is Resizable BAR enabled?
  • What steps have you tried to solve this issue?
  • When the screen is black, and the mouse and keyboard aren't recognized, do you need to shut down the system as a temporary solution to resume using it?
  • Also, we would like to ask for more system information. Please create a system report using the following tools:
  •  Intel®️ System Support Utility (Intel®️ SSU):
    • Download the Intel SSU
    • Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
  • Intel® Graphics Command Center report:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Hello TheRitrax,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello TheRitrax,
Best regards.
Jean O.
