I have a notebook Asus n56jr with:
bios: 201 (N56JRH),
Windows 8.1 Update 1,
Intel HD Graphics 4600,
nVidia GTX 760m.
The problem is a flicker effect that occurs on dark backgrounds and lowering the brightness.
I have installed different versions of the Intel driver:
win64_153314.exe
win64_153318.exe
Asus VGA_Intel_Win81_64_VER1018103355
but the problem persists.
The problem reduces, but does not disappear, if I disable the UEFI bios.
Can anyone help me?
Thanks a lot,
blu
链接已复制
Hello Blu, I am sorry to hear that you are having issues with your system and the HD4600. I would suggest you to install the original driver provided by ASUS and check if the behavior persists or not.
http://www.asus.com/Notebooks_Ultrabooks/N56JR/HelpDesk_Download/ http://www.asus.com/Notebooks_Ultrabooks/N56JR/HelpDesk_Download/
You can also try our latest graphics driver provide at the following link. https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714&lang=eng https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714&lang=eng
Remember that our drivers are generic drivers and they are made for Intel Motherboards, but you can try it.
Hello sylvia_intel,
thanks for your help.
Unfortunately, the Intel driver and the Asus does not have solved the problem.
I also tried this way (without success).
I noticed that when I uninstall the Intel driver and leave the default to Windows:
Windows sets the refresh rate to 64hz.
When I install the Intel driver monitor refresh is set to 60hz.
The new Intel drivers have a feature that allows you to set a new profile with a custom refresh. Unfortunately only accepts 60hz. Higher or lower values not are allowed.
Thanks a lot,
blu
