Hi Guys
I just need some assistance with an issue i seem to be having with a few machines. I have a bunch of PC on a work bench. They are connected in pairs to aten 2 port USB KVM's. Now i noticed that when i switch screen the resolution looked off when i came back to the pc. What i noticed is that when i switch pc's the resolution drops from 1440X900 to 1152X864 and no matter how many times i change it back to 1440X900 when i switch from one pc to another and back again it has reverted back to 1152X864. Now i have a mix of pc's configured in this setup and i have noticed it only happens with those that are running the G33/G31 chip. the others are running other intel chipsets and they work fine it is isolated to the G33/G31. I have tried updating drivers and rolling back and still no joy. Any help you could provide would be great thanks
Cheers
Hi ekartoon,
Have you tested using straight cables? VGA to VGA or DVI to DVI for instance. Bear in mind KVM switches are not supported by the Intel graphics controller. See the following URL for more information:
http://www.intel.com/support/graphics/sb/CS-033418.htm http://www.intel.com/support/graphics/sb/CS-033418.htm
Allan
