I cant launch GPA
The program does not work in most games despite the supported engine, and I do not understand why? When I manually launch it through the program, I see that GPA starts working, but I cannot play like that because they will not let me play without initializing the anti-cheat, in this case I mean the games: PUBG, Rust, Squad, and many others. Please tell me what the problem is and can it be fixed on the client side? Maybe I'm doing something wrong?
I also read the description and user manual on the official website but found nothing regarding my problem, despite the fact that there is a corresponding category there.
Thank You!
Anti-cheat systems like BattleEye (used in PUBG and Rust) or Easy Anti-Cheat (used in Squad) can block other applications (like GPA) from running properly alongside the game. This is often a security measure to prevent cheating. Try launching the game with anti-cheat enabled first, and then try running GPA after the game has loaded. Some games might require GPA to be explicitly whitelisted. Some anti-cheat systems may actively block GPA from interacting with the game. Check if there’s a way to whitelist GPA in the anti-cheat software settings, or if there’s a "GPA mode" that disables anti-cheat temporarily (though, this may be tricky with games that are strict about cheating). If none of the above works, and you've already read the official user manual, reaching out to GPA’s official support or forum might be the best step
