23272 Discussions
GTA 5 - Not detecting the proper amount of VRAM
ForeverBlue
Using the Intel Graphics UHD 630, GTA 5 will detect around 4 GB VRAM for an odd reason, causing the game to cache graphics into RAM - too much at least.
A similar issue existed in GTA 4, except the game was detecting too little VRAM, causing the caching to barely function at all and objects were "popping in" in front of you while previously loaded objects were popping out. A way to fix this was using a commandline that says -avaliablevidmem 10. Unfortunately, GTA 5 didn't come with that type of compatibility.
Due to this, GTA 5 will boot at optimal performance, then after a few minutes depending on graphics settings it'll begin to cache way more than it should. My system is on 8 GB RAM and due to my page file being on an HDD, it began stuttering awfully.
Basically, how could I go about changing the VRAM cap so I can lower it to a respectable amount so it doesn't cache as much? Or how can I assist GTA 5 into not over-caching more than my system can handle?
Alberto_Sykes
ForeverBlue, Thank you for posting in the Intel® Communities Support.
In reference to your question about the VRAM, here you have the specifications of how it works:
VRAM is a special-purpose memory used by video adapters.
VRAM is dynamic
The VRAM cannot be increased because of a hardware limitation.
The video memory can get up to 50% from the system RAM, depending on the processor model and operating system
In the following link you will find further details about this topic:
https://www.intel.com/content/www/us/en/support/articles/000020962/graphics.html
Albert R.
A Contingent Worker at Intel
ForeverBlue
Thanks for the reply,
I'm fully aware about how VRAM works, the issue is that GTA 5 grabs too much system RAM to use as VRAM and there is no config or graphic setting to change how much GTA 5 will use for caching graphics.
On my system it caches up to 4 GB, which on an 8 GB system 4 GB for just VRAM I assume will cause it to get cached into a pagefile. I use a 7200 RPM HDD which might explain the drop in FPS, because it is not a reliable pagefile for GTA 5.
Basically I want GTA 5 to use less system RAM for VRAM, as it's using way more than it needs (it can go down to 900 MB on other systems with other specs)
Alberto_Sykes
ForeverBlue, You are very welcome, thank you very much for providing that information.
The VRAM cannot be increased or decreased because of a hardware limitation and because it is automatically assigned by the Operating System.
Albert R.
nx
but when i played gta v 1 year ago, it showed 1024 vram, but now its just 512, i didn't make any hardware or software changes, gta v is not detecting my vram properly plz fix
