22661 Discussions
Game Support-Elden Ring Nightreign
John_nai
Recently updated to the newest Intel Iris Xe gpu 32.0.101.6795, which literally says that it has built-in Intel® Arc™ GPUs for Elden Ring Nightreign. Attempted to run the game and all it does is crash after a period of white screen. I then disabled the intel iris xe gpu and ran the game on only microsoft display adapter and the game launched perfectly fine, although I still can not run it due to poor fps. Is there anyone who can help me understand what's happening and whether there is a fix?
My device is a laptop, 13th Gen Intel® Core™ i7-1355U
Rin
I facing the same issue but when i try to run the game on older version of iris xe graphics (v27) the game launche is just fine but as soon as i play the game there is a red tint on the charecter that im playing and also on the enemies as well.
kanad3
What fps did u have in the game and did that red tint make your gameplay harder by any means?
Rin
I get around 30 to 40 fps at 720p on low graphics and yeah im not able to play the game at all that red tint is all over my screen i was barely able to see my ingame character.
ζㅌyl
hello sorry for late reply,
this video might help tou.
https://youtu.be/-PCGksZmB5k
dont forget to turn off anti-cheat.
Rin
the dll injector u sent didn't workout for me. since the game is d3d12 the option to disable shader is not present on my special k.
btw im sharing some screenshot to show u how my game runs like the red tint im talking about.Screenshot (1).pngScreenshot (2).pngScreenshot (3).png
ζㅌyl
have you tried other driver version or is this the only version that works?
Rin
It only works on 27.20.100.8935
I also tried the latest one but my game crashes on launch
Rin
If only i could show you the screenshots its unplayable
John_nai
Can you link me to the download of version 27? I can’t seem to find it
Rin
DxCode
what is your cpu series? can the 12 series downgrade to an older version
Rin
i5 11th gen 11300h idk about the 12 series
DxCode
series 12 can't downgrade to version 27.20.100.8935
Rin
ζㅌyl
Nugerah
i can't install version 27 on my laptop
DhannielM_Intel
Hello John_nai,
Thank you for posting in the community! I see that you’re discussing how to resolve the same issue, so let’s set the right expectations first.
The Intel graphics driver does not contain a built-in Intel Arc GPU. I’m curious where you might have seen this, as I checked the release notes, and there’s no mention of the Intel Iris Xe graphics driver including Arc GPU functionality.
Regarding the system requirements for Elden Ring: NightReign, the minimum GPU requirement is a GTX 1060 or RX 580 both of which are more powerful than Intel Iris Xe and better suited for handling the game’s demanding graphics. Additionally, the game requires at least 3 to 4 GB of VRAM, whereas Iris Xe relies on shared memory with RAM, making it unsuitable for running the game optimally.
I’d like to investigate further, so could you answer the following questions:
  • What is the exact model of your laptop?
  • Do other AAA games like Elden Ring exhibit the same issue?
  • Have you tried performing a clean installation using DDU?
  • Can you share your in-game graphics and display setting?
Furthermore, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here: Help Guide for the Intel® System Support Utility
Dhanniel M.
ζㅌyl
ζㅌyl
as of patch 1.01.1, nightreign still wouldn't fixes theit whitescreen crash issues, this may have something to do both the game and the drivers which i hope intel would release for iris xe
PepoIRISXEl29
New Contributor III
Don't tell me man. You are having similar problems in the game than in the last of us part 2. They probably won't fix it (or fix it for Christmas) idk.
