22923 Discussions
Glut/OpenGL always renders black window
fazooladmi
I am changing the window background color using the Glut library, which isn't working. The code works perfectly on my peer's computers but not on mine. I am using Visual Studio on Windows 10, with intel i5,8th gen, with integrated graphics. I searched on Reddit threads, and the only thing relevant was that integrated graphics may be the issue.
Is integrated graphics really the issue or something else?
Are there any solutions to this problem, except changing the graphic cards?
Note- The library should be OpenGL, glut, glu only...
Code:
#include <GL/glut.h>
#include <gl/GLU.h>
#include <iostream>
using namespace std;
void draw() {}
void display() {
  glClearColor(1.0, 1.0, 0.0, 0.0);
  glClear(GL_COLOR_BUFFER_BIT);
  gluOrtho2D(0, 640, 0, 480);
  // draw();
  glFlush();
  return;
int main(int argc, char **argv) {
  glutInit(&argc, argv);
  glutInitDisplayMode(GLUT_RGB | GLUT_SINGLE);
  glutInitWindowPosition(200, 200);
  glutInitWindowSize(640, 480);
  glutCreateWindow("House");
  glutDisplayFunc(display);
  glutMainLoop();
  return 0;
I tried this code, and although it renders a window, it is black in color, which it should not be. It should be (as the question) any random color. Are there any solutions i can try?
Jean_Intel
Hello fazooladmi,
  • Is the issue present in the software or application that you are developing?
  • When did the issue start?
  • Can this issue be replicated on third-party graphics cards?
  • Create a report using the Intel®️ System Support Utility (Intel®️ SSU)
Jean O.
Jean_Intel
Hello fazooladmi,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello fazooladmi,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
