22940 Discussions
God of War - Performance Issues
boazvdw
I'm trying to play GoW, but it's near unplayable. Depending on what direction I'm facing I'll go from 70-100fps to 30 or lower. I tried switching to DXVK which improved stability slightly, but it's still unplayable. Is there anything I can do to make it a bit less painful to play?
Specs:
Driver version: 31.0.101.3975
Mobo: Asus Hero VIII
GPU: Arc A770
CPU: Ryzen 5600X
RAM: 32GB 3200MHz
Re-Bar: Enabled
boazvdw
Attaching my SSU log.
Carlos_L_Intel
Hi @boazvdw
Thank you for posting on the Intel®️ communities. Please accept our apologies for any inconvenience this might have caused you, I'll do my best to help you get this fixed.  In order to help you please provide me with the following information:
  • When did the issue start? Were there any recent changes?
  • Did you have any other graphics cards installed previously?
  • Are you using a straight cable into the port or are you using any type of adapter or docking station?
  • Please run a graphics report following this article, especially Intel Graphics Command Center (Intel GCC)
  •  Have you tried the previous driver .3959: https://downloadmirror.intel.com/762922/gfx_win_101.3959.exe
Carlos L.
Carlos_L_Intel
Hi @boazvdw
Carlos L.
Carlos_L_Intel
Hi @boazvdw
Carlos L.
Carlos_L_Intel
Hi @boazvdw
 Thank you for your time. We have been able to reproduce the issue and a bug report has been filed with our driver debug team, bug ID 14017239624. We can't promise any particular outcome or ETA for a fix but rest assured that we are investigating this issue and working hard to improve performance with this game. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Carlos L.
