23696 Discussions
Graphic driver keeps crashing
KFlor1
Hi, my new Asus UX305CA UHMI Zen book arrived a couple weeks ago. The graphic driver keeps "crashing" then recovering.
Here is what my system says I have: Intel R HDGraphics 515 : Processor is Intel R Core m3 6Y30 : Direct X runtime 12.0 : Driver version 20.19.15.4285
I downloaded the intel utility for updates...but it never shows any graphic drivers needing update.
when it "crashes" the error says: intel hd graphic driver for Win 8 (R) has stopped working or recovered.
does this mean I have a Win8 driver?
can someone point me to the correct driver to install and do I have to uninstall the old one first ?
Many thanks~~~Kelly
KFlor1
It came installed with Win10
EstebanA_C_Intel
Hello, BayfieldBunch:
Have you tested your system with the VGA driver Version V20.19.15.4300?
This version is newer, so it could include a fix for that.
Here you can find this driver, just make sure you select Windows 10*.
http://www.asus.com/Notebooks/ASUS-ZenBook-UX305CA/HelpDesk_Download/ ASUS ZenBook UX305CA | Notebooks | ASUS Global
Is this happening with an specific software? Do you have the latest revision/version of that software? or are you able to test with different versions?
I look forward to your outcome.
Esteban C
KFlor1
Thank you, I'm downloading that VGA right now.
I seem to remember reading that you are suppose to delete the old one first?? but I am hesitant to do that. Will just download new one and see how it goes....
KFlor1
I downloaded that new version, still crashing.... says Win 8 (R)
should it not be a Win 10 driver? I did not delete old driver before downloading new...is that a problem ?
EstebanA_C_Intel
It would be better to select the check mark while uninstalling the driver to remove software related.
Please refer to the screenshot below and advise me with your outcome.
Esteban C
